92 Rear Engine Mount Replacement ??
Old Jul 14, 2008 | 08:59 AM
s13_240sx_92's Avatar
Default 92 Rear Engine Mount Replacement ??
I have to replace the rear engine mount (closest to firewall) on my 92 Prelude.
My questions to those who have done it already:
Is it accessible if you unbolt the engine/trans bracket? It looks like it would be hard to unbolt it from the sub-frame.
Do you access the bolts from the top or bottom?
It looks like a PITA to do without removing a lot of stuff.
Thanks all.
Old Jul 14, 2008 | 09:11 AM
Hawkze_2.3's Avatar
Default Re: 92 Rear Engine Mount Replacement ?? (s13_240sx_92)
The mount is held onto the subframe by 3 bolts that go in from the top, then there's one through bolt holding the mount to the engine/tranny mount. If you can, I would remove the intake manifold and make your life a LOT easier, but you don't have to.
This pic might help also, it is with no IM:
Old Jul 14, 2008 | 10:10 AM
Default Re: 92 Rear Engine Mount Replacement ?? (Hawkze_2.3)
Thanks Hawk! I was hoping that I would not have to remove the intake.
Anyone replace this without removing the manifold?
Old Jul 14, 2008 | 10:36 AM
donger's Avatar
Yea, it's accessible from the bottom, but requires small hands and a lot of shifting of the engine mount and the bracket, kinda like playing tetris, haha. I cant remember if I inserted it with the bracket and mount attached to each other or if i put in each one separately. You may also have to jack the engine up a little bit to get the bolts to line up.
Old Jul 14, 2008 | 11:33 AM
lude98SH's Avatar
Default Re: 92 Rear Engine Mount Replacement ?? (donger)
if u remove the TB and the intake u can get at it but its not that easy. I needed a swivel and long extension.
Old Jul 14, 2008 | 12:23 PM
vinuneuro's Avatar
Default Re: 92 Rear Engine Mount Replacement ?? (lude98SH)
Not entirely sure about the 4th gen, but with the 5g you don't need to remove the tb. All you need is a really long extension. Slip it between the throttle cable and tb/manifold to get to the front bolt. Slip the extension behind the tb/mani to get to the right bolt.
Old Jul 14, 2008 | 01:20 PM
lude98SH's Avatar
Default Re: 92 Rear Engine Mount Replacement ?? (vinuneuro)
hmm maybe ur right. i usually took it off without even seeing if i had to
Old Jul 16, 2008 | 08:55 AM
Thanks guys. I figure I will try from the under side and if that doesn't work I will have to breakdown and remove the mani.
Old Jul 16, 2008 | 09:35 AM
vinuneuro's Avatar
There's a diy on how to replace the rear mount on a 4th gen. It doesn't involve removing the tb or mani.
jmanuel
Jul 8, 2014 11:47 PM
TheOdd001
Feb 17, 2010 05:02 AM
c0d0r
11
Jan 29, 2008 12:00 PM
Sweetsystem
Jan 2, 2007 12:13 PM
CristalCleanCivic 97 EX
Aug 8, 2003 10:39 AM
