Fan switch problem
Old Aug 5, 2008 | 10:51 AM
Lovemy99Lude's Avatar
Default Fan switch problem
Hey guys, I couldn't find a thread about the fan not working properly so I thought I would just post and ask. My '99 prelude's a/c & fan switches only works on the high level. Is this a situation where i can just replace the top fan controls or is it somethings else to get all fan levels to work? Please help!
Old Aug 7, 2008 | 07:00 PM
mongtite's Avatar
Default Re: Fan switch problem (Lovemy99Lude)
what do u mean work only on high level??? I thought AC Fan works everytime U turn the AC on.
Old Aug 7, 2008 | 10:10 PM
JDC2TypeR's Avatar
you could wire it so that it works everytime ou turn your car on. just by wireing the black to a ground and the blue wire to your fuse or to yur positive on your battery or just connect it to a on off switch
Old Aug 8, 2008 | 05:18 AM
Default Re: (JDC2TypeR)
The fan and a/c works and blows cold air, but for some reason I can only have it on when its on the high level. The low, and two medium switches dont work...no air blows until the last level.
I dont want to wire it so the a/c runs none-stop, I want it running like normal. I think I the lower level fan levels are broke. Would I swap out a new control component? Fuse problem?
Old Aug 8, 2008 | 01:17 PM
mongtite's Avatar
Default Re: (Lovemy99Lude)
If you are talking about the **** only then, yes theres differently something wrong with it. The **** is just a potentiometer that has divided resistance that allow certain amperage to run across. This Fan is not the coolant AC fan, it is the air blower fan for both AC and Heat. the Fan works, so U can take that off as a possible defect. It must be the **** thats bad.
Old Aug 9, 2008 | 06:30 AM
Default Re: (mongtite)
Ok that's what i was hoping for. I will have to take that switch apart to find out what is exactly wrong. Hopefully its an easy fix.
john79
May 25, 2018 05:04 AM
josemt
Jun 23, 2010 06:24 AM
manny81
Apr 22, 2007 12:23 PM
hondateg10
Apr 5, 2007 08:41 AM
