Internal coil replacement
Old Jul 26, 2008 | 07:22 PM
drbenne's Avatar
Default Internal coil replacement
Looking to replace my bad internal coil in my jdm h22 distributor. What other models can be used? I know the cap and rotor from a 2000 civic SI fits because i just bought one... will the coil from the same civic work in a jdm h22 dist?
and no i don't want to convert to an external coil...
Old Jul 26, 2008 | 07:37 PM
Acidcrakker's Avatar
Default Re: Internal coil replacement (drbenne)
Usally the best thing to do, is to just replace the whole Dizzy itself.
Old Jul 26, 2008 | 08:22 PM
drbenne's Avatar
Default Re: Internal coil replacement (Acidcrakker)
Well if I replaced the whole thing I would want a brand new one and a coil itself is alot less. Plus, I already have an extra dist for parts, just need a another coil.
Old Jul 26, 2008 | 08:28 PM
Hawkze_2.3's Avatar
Yeah, I would just look for another H internal coil, I believe the actual distributors are different from Civic to Prelude despite the caps being the same(not sure about the coil). However, IF the distributors were the same we could use a billet MSD distributor on our Preludes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Usally the best thing to do, is to just replace the whole Dizzy itself. </TD></TR></TABLE>
So instead of buying one small part that would fix the problem he should buy a much bigger part that he doesn't even need all of? Also, what is the comma for?
Old Jul 26, 2008 | 08:41 PM
drbenne's Avatar
Default Re: Internal coil replacement (Hawkze_2.3)
I thought I read somewhere that coil's from an accord and civic can be used, just not sure from what years and models. Hopefully someone can chime in because for some reason I couldn't find it when I searched for coils.
Old Jul 27, 2008 | 04:45 PM
drbenne's Avatar
I got the coil for the 2000 civic si, worked perfectly.
Old May 25, 2009 | 01:19 AM
95dsfreakjason's Avatar
ok the easiest and most reliable thing to do it buy a new distributor. for a h22 with a internal coil is hard to find. the p/n is td-60u there are a few on ebay for like $120. its for the jdm prelude which had an internal coil.
Old May 25, 2009 | 06:26 AM
drbenne's Avatar
All that was needed was a new coil which I already changed. The dist was working perfect so there was no reason to get a new one. This thread was made almost a year ago and that civic coil is still working with no problems.
Quade
Mar 14, 2008 09:47 AM
BreakMaster
Sep 9, 2004 11:49 PM
dominate9
Aug 24, 2003 03:37 PM
CBR
Apr 10, 2002 08:44 AM
