01 sh blown engine
Ok heres the deal i was out of a job and money so i put off changing my oil and the worst happened. I heard knocking from the engine and then it stalled.
. I was wondering what i had to fix to get this car running again. So plz help me fix my mistake
so one of your rods flew out? You should tear it apart see if the head is still good, If it is then get a h22 or H23 block, and head haskit and clean out head very good, and out it back together. Or get a new H22 motor.
just my 2 cents
just my 2 cents
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cartel4 »</TD></TR><TR><TD CLASS="quote"> I was wondering what i had to fix to get this car running again. </TD></TR></TABLE>
You have to fix the engine block. Obviously something major happened, so you need to find out what it is before you know what needs to be fixed. You sound like you have no clue, so you will have to have someone else fix it and it is going to cost you a lot.
You might consider getting a used JDM engine, they can usually be found for cheaper than a rebuild.
Hmotorsonline is good....and there's some others that I can't think of right now. Google should help, but do research before you buy to make sure they have good customer feedback
I would go with Hmotorsonline,just call them to see what shortblocks they have instock then go from there...or do a rebuild which will most likely cost more if your having a shop put it all together
x2.
Labor hours, they should be able to save you some money if you remove entire motor and just drop in a new one. The labour honestly is what kills you most of the time. The motor is usually only a 1000 dollars, but with a shop installing it, its going to be an extra 1000-1500 dollars (hopefully not more than that, if anything maybe less, but they do like to brake things, and than charge you ;saying it was faulty anyway (even though they are suppose to ask you if you'd like it replaced first (and yes I'm speaking from first hand experience lol)
sirLUDE
Sep 28, 2006 09:56 PM
H23preludeSi
Jun 4, 2004 09:49 AM
Nikoli
May 15, 2004 11:24 AM
