Bushing Grease
Old Aug 3, 2008 | 08:10 AM
kornerk12's Avatar
Default Bushing Grease
Where exactly are you supposed to grease bushings ? What grease do you use ? Is it necessary to grease new bushing or are they prelubed ? What about black ES suspension bushing do they need to be greased ?
Old Aug 3, 2008 | 09:29 AM
slamdlude's Avatar
Default Re: Bushing Grease (kornerk12)
The ES bushings will squeak if not greased. Well, they will squeak if greased, but not as bad. Everywhere that the bushing will be touching metal needs to be greased. If you bought the ES kit it should have come with grease. If not go to your local parts store and pick some up. It is sold in the ricer section in autozone.
Old Aug 8, 2008 | 06:21 PM
kornerk12's Avatar
Default Re: Bushing Grease (slamdlude)
Where am i greasing ? Im using factory replacement bushings. Am i greasing the sleeve where it touches the LCA or do i just grease the bushing around the outside that would touch the subframe? (I guess the reason would be for longevity in that case)
Should they press right in ? How do i install these ?
SlimBB4
Feb 13, 2010 07:09 AM
DA9_DAD
Apr 23, 2009 12:57 PM
disposable
Jul 31, 2005 08:36 AM
thrill91si
May 16, 2003 09:34 AM
Jaminak
23
Jun 6, 2002 12:57 PM
