Drilling through firewall
Old Aug 4, 2008 | 03:36 PM
geoffme's Avatar
Default Drilling through firewall
I have a 92 Prelude SI, and I am trying to run my 2 gauge power wire through the firewall, and I can't find a spot to drill, does anyone have any suggestions?
Old Aug 4, 2008 | 03:56 PM
92SR4WS's Avatar
Default Re: Drilling through firewall (geoffme)
I dont think you need to drill a hole... just put it through where the other wires go through from the fuse box.
Old Aug 4, 2008 | 04:02 PM
G2IntegraGS's Avatar
yeah there will be a spot thats already drilled. I wouldnt suggest drilling the firewall.
Old Aug 4, 2008 | 04:58 PM
geoffme's Avatar
I can't find any such spot, It's a really cramped area.
Old Aug 4, 2008 | 05:16 PM
twiztid00002's Avatar
if the wires you need to get past the firewall have to hook up to a positive 12V just hook it up to the headunits power instead of the battery. thats wat i did for my gauges. the wire is most likely yellow and it will probly have a lil fuse box on the wire
Old Aug 4, 2008 | 05:18 PM
Finest's Avatar
Remove the fusebox. There's room underneath.
Taken from a nitrous install at: https://honda-tech.com/zerothread/2261379
Also, remember to use a rubber grommet whenever running power wires through the firewall. Vibration and movement will rub the wire's insulation against the sharp chassis hole and it'll ground itself. Don't ask me how I know.
Old Aug 4, 2008 | 05:20 PM
Finest's Avatar
Default Re: Drilling through firewall (twiztid00002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid00002 &raquo;</TD></TR><TR><TD CLASS="quote">if the wires you need to get past the firewall have to hook up to a positive 12V just hook it up to the headunits power instead of the battery. thats wat i did for my gauges. the wire is most likely yellow and it will probly have a lil fuse box on the wire</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geoffme &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 Prelude SI, and I am trying to run my 2 gauge power wire through the firewall, </TD></TR></TABLE>
2ga wire is pretty hefty, I'm assuming he's powering an amp with it.
Old Aug 4, 2008 | 07:01 PM
Default Re: Drilling through firewall (Finest)
Wow pics and everything. Considering the size of that line they used you should have enough room. Like said earlier dont forget the grommet!
Old Aug 4, 2008 | 10:07 PM
geoffme's Avatar
Thanks everyone. =] The help is much appreciated =]]
and actually the 2g is just for now, I am hooking up 0g here soon I am running 2 1000 watt rms amps
Old Aug 6, 2008 | 01:16 PM
geoffme's Avatar
Old Aug 7, 2008 | 05:40 PM
Finest's Avatar
Default Re: Drilling through firewall (G2IntegraGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS &raquo;</TD></TR><TR><TD CLASS="quote">Wow pics and everything. </TD></TR></TABLE>
Well, like they say: pictures are worth a thousand words. And since I didn't want to type out a thousand words, I used the vast resources of H-T to get the point across.
2,000 watts, good lord! Let's see this thing in action when you're done! How many subs are you running back there?
Natethagreat
Audio / Security / Video
Apr 24, 2011 12:53 PM
tim.simpson
Nov 16, 2008 12:23 PM
Daniel_san
14
Oct 1, 2003 02:42 PM
Jeff_G
Oct 5, 2002 05:41 PM
JoshRambo
Jul 20, 2001 03:42 PM
