h22a4 engine mount different?
Old Jul 29, 2008 | 09:27 AM
dartonh22's Avatar
Default h22a4 engine mount different?
i have a 99 h22a4 sh block in my 93 prelude with innovative mounts and the car has a bad vibration between 30 and 50 i have had this problem for a long time and have tried everything axles, tires, ball joints tie rods, anyway i think my problem is the rear engine mount bracket or the drivers side engine mount bracket that bolts to the block and the mount bolts to it.
my question is
is the rear automatic bracket different from the manual trans bracket from 92-96
and is the drivers side engine mount bracket that bolts to the engine: then the urethane filled mount bolts to it, different from 93-99
i know the part numbers from majestichonda are different and i know they will fit in the car beacuase thats what is in my car. but i had to do some banging to get them to fit. i thought they were hard to fit in just because of the aftermarket mounts.
Old Jul 29, 2008 | 12:26 PM
mgags7's Avatar
You should never have to bang anything to get it to fit if it is the correct part.
The automatic trans mounts are definitely different.
The welded-on trans mount in an automatic car is different, as well as the bolt on trans mount.
Old Jul 30, 2008 | 05:24 AM
dartonh22's Avatar
Default Re: (mgags7)
i know the actual trans mount is different but what about the rear T bracket from the automatic?
Old Jul 30, 2008 | 05:29 AM
mgags7's Avatar
I would assume yes, but there is no way to be sure.
Was your car an auto?
Old Jul 30, 2008 | 08:51 AM
dartonh22's Avatar
no i took my motor out to get it built and left it at the shop with the mount still attached and when i got it back it wasnt on there, but i forgot to check for it and when i got home i just used the T bracket from a auto car that i swapped. because the shop was 3 hrs away. i am mainly wondering about the timing side motor mount bracket and if there different between h22a4 and h22a1.
Old Jul 30, 2008 | 08:52 AM
mgags7's Avatar
The timing side should be the same.
Why don't you call the shop and have them ship the mounts to you?
Old Jul 30, 2008 | 09:42 AM
dartonh22's Avatar
yeah i was gonna stop by the next time i go back to my brothers(its on the way) but i just wanted to make sure. not to mention doing the work for nothing, but i will most likely do that, just figuired id see if someone on here knew for sure.
EKcivicEK
18
Jul 29, 2021 12:51 AM
scooterpies
Apr 13, 2017 04:03 PM
kelsodeez
Jan 9, 2010 09:33 PM
jaskuloski97sh
Jul 20, 2007 09:30 PM
TurboLaxx
19
Feb 20, 2006 11:37 PM
