help with engine harness
Old Jul 31, 2008 | 05:04 PM
spooled-r's Avatar
Default help with engine harness
i have a base model 98 prelude that i bought not running and it had a type sh harness on it so i had to swap to the base moddel harness and have a couple plugs i can find the plug spots for does anyone have or know were to get a layout or diagram showing were everything plugs in
Old Aug 4, 2008 | 08:26 AM
spooled-r's Avatar
Default Re: help with engine harness (spooled-r)
bump!!!! okay there is actually onle one part i need help w its a single yellow w red stipe wire and its not a plug it has to be bolted on i was looking all over the engine cant find were it goes hope some one might know
Old Aug 4, 2008 | 09:10 AM
G2IntegraGS's Avatar
Well the sh has the ATTS system and im sure that could account for some of the plugs. You should have marked the plugs before you removed them since some plugs will plug into more than one spot.
Old Aug 4, 2008 | 09:46 AM
spooled-r's Avatar
Default Re: help with engine harness (G2IntegraGS)
i got all the plugs in but when i took the old harness off this wire was cut and in my new harness cant figure out were it goes but it takes a screw its not a plug
Old Aug 4, 2008 | 09:57 AM
spooled-r's Avatar
this is the only wire i can figure out
[IMG][/IMG]
Old Aug 4, 2008 | 10:05 AM
spooled-r's Avatar
sorry the pic didnt work but its on the drivers side close to the oil filter and knock sensor
Dr_potatohead
Dec 29, 2014 03:48 PM
Asmooh
Apr 23, 2014 04:32 PM
toyotaninja
Apr 23, 2011 04:22 AM
Crx_Civic
Apr 27, 2008 11:41 AM
