code 12 how to fix??
Old Oct 2, 2008 | 03:33 PM
SiR Inspired ED7's Avatar
Default code 12 how to fix??
This is for a friend.
My friend has a 94 prelude Type S recently swapped in a h22a and he is getting code twelve wich is Exhaust Gas Recirculation. We have no idea where to locate this sensor. Anyone help?? THNX
BTW he is also throwing code 23 witch is the knock sensor but we know how to fix that. That wouldnt cause code 12 to come out would it?? Can we use a B16/B18c knoc sensor on the h22?? Or are they different??
Old Oct 2, 2008 | 03:50 PM
teambk8's Avatar
Default Re: code 12 how to fix?? (SiR Inspired ED7)
Its in between the IM and the valve cover near the throttle body. It doesn't look like a typical sensor click here for a pic:
http://alflash.com.ua/Honda/EGRvalve.jpg
take it off, clean it and the space below it with carb cleaner... install and reset ur ecu.
Old Oct 2, 2008 | 03:57 PM
slamdlude's Avatar
Default Re: code 12 how to fix?? (teambk8)
You might have to clean the egr ports if cleaning the valve doesn't work. I think the 95 and up manifolds came with plugs that can be removed with allen wrench, but older ones came with plugs that have to be drilled and replaced. They are located on top of the runners. http://autorepair.about.com/li...c.htm This link is for an accord but it is the same process.
Old Oct 3, 2008 | 01:42 PM
Default Re: code 12 how to fix?? (slamdlude)
Ill let my friend know... THNX alot.
Old Oct 3, 2008 | 03:29 PM
vthondaboi's Avatar
How about for H23s, those ports are welded on!?!?!
Old Oct 3, 2008 | 04:49 PM
Default Re: code 12 how to fix?? (vthondaboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vthondaboi &raquo;</TD></TR><TR><TD CLASS="quote">How about for H23s, those ports are welded on!?!?!</TD></TR></TABLE>
HUH??
Old Oct 4, 2008 | 09:22 AM
slamdlude's Avatar
They look like welds but they aren't. It is just solder like stuff. Follow the instructions in the link I posted above to clean the ports.
technine
Apr 18, 2007 10:51 AM
Stevegunit16
Feb 14, 2007 09:14 AM
AccordRacing
May 26, 2005 07:06 PM
accord0494
Mar 4, 2005 04:47 PM
EuRoBrO
Jul 21, 2004 02:05 PM
