clutch issue
Old Sep 27, 2008 | 08:58 PM
cadwiese's Avatar
Default clutch issue
hey im changed the slave and master cylinders on my friends 94 prelude si and now im not getting any pedal feedback we tried to bleed the system like 3 times and are not getting anywhere
plz help
Old Sep 27, 2008 | 09:28 PM
elude714's Avatar
Default Re: clutch issue (cadwiese)
How are you bleeding the system?
Also are you seeing any bubbles?
Are you leaking anywhere?
Old Sep 27, 2008 | 09:53 PM
cadwiese's Avatar
Default Re: clutch issue (elude714)
we are bleeding the system the way the manual said to.
we are seeing some bubble for a bit but now none.
no we are getting no leaks
Old Sep 28, 2008 | 05:37 AM
Apex1972's Avatar
did you add brake fluid to the master cylinder before you mounted it to the booster? If not, you may have air still in the master cylinder. I had the same problem. Also , the fitting located above the transmission where the line goes into a banjo type fitting, you may need to bleed from there too. Getting all the air out is the hardest part of the job man, just be patient.
Old Sep 28, 2008 | 06:26 PM
cadwiese's Avatar
we got it we had to bleed the crap out of it
Old Sep 28, 2008 | 06:42 PM
TheJGB3's Avatar
Yep, it takes a very LONG time. I just did mine last week, and I was afraid I needed a new master since I had no pedal pressure after pumping for a long time...then finally pressure returned.
Old Sep 28, 2008 | 07:09 PM
dagle's Avatar
Default Re: (TheJGB3)
haha same thing happened to me in my s2k. i thought i could get it without recycling clean brake fluid (the stuff pumping out) well my arrogance resulted in 3 trips to kragen for brake fluid. also due to a small leak in the slave, thankfully all is well now
Old Sep 29, 2008 | 08:38 AM
jardolei's Avatar
It takes FOREVER to bleed the clutch..... My 5th Gen slave cylinder took almost 15 minutes....
autoxthis
Transmission & Drivetrain
Sep 18, 2008 12:50 PM
autoxthis
Honda Civic (2006 - 2015)
Aug 24, 2008 05:46 PM
autoxthis
Aug 21, 2008 08:23 PM
ferio 95
Jul 22, 2005 10:03 PM
