Wheels sizing
Old Sep 30, 2008 | 07:54 PM
es_squared's Avatar
Default Wheels sizing
Quick question. I might be going for a set of 17x8 wheels, +35 offset. I'm lowered 1.9/1.6 for the front rear.. think it will rub ?
Old Sep 30, 2008 | 11:55 PM
ManjuGrip's Avatar
if you use something like a 215/40/17 you should be fine. Thats my set up right now. but it also depends on how stiff your suspension is.... theres a few variables to considder.
Old Oct 1, 2008 | 07:05 AM
es_squared's Avatar
Default Re: (ManjuGrip)
hmm alrighty. im on H&R race springs which are pretty stiff, and KYB AGXs
Old Oct 1, 2008 | 04:31 PM
Kronn 98SH's Avatar
Default Re: Wheels sizing (es_squared)
215 tire is pretty narrow for an 8" rim. 215mm = 8.4"
that would only give you 0.2" (or 5mm) extra on each side of the wheel.
also:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.ottawaprelude.ca &raquo;</TD></TR><TR><TD CLASS="quote">
OFFSET:
6.5" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: You take the chance of rubbing the outside lip of the wheel well.
+38mm to +55mm ::: You shouldn't have any problems. Recommended Offsets for 6.5" Wide Wheels.
Larger than +55mm ::: You take the chance of rubbing the inside lining of the wheel well.
7" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: Not Recommended
+38mm to +41mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well.
+42mm to +44mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well.
+45mm to +50mm ::: You shouldn't have any problems. Recommended Offsets for 7" Wide Wheels.
Larger than +51mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
7.5" Wide Wheels w/ 4th & 5th Gen
Less than +40mm ::: Not Recommended
+40mm to +43mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using any tire with an overall diameter larger than stock and/or with a tire width larger than 215.
+44mm to +47mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using a tire with an overall diameter more than slightly larger than stock, you chances of rubbing increase.
+48mm to +52mm ::: You shouldn't have any problems. Recommended Offsets for 7.5" Wide Wheels.
Larger than +53mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
8" Wide Wheels w/ 4th & 5th Gen
Not recommended without enlarging or rolling outside lip of wheel wells. Some people have had success with running offsets larger than +48mm, but you are taking an expense risk.</TD></TR></TABLE>
Old Oct 1, 2008 | 05:55 PM
DeyAinRdy4Ds's Avatar
Default Re: Wheels sizing (Kronn 98SH)
i got 225s on an 8.5, so 215s MAY work on an 8....but 225s would prob b ur safest bet
Old Oct 1, 2008 | 06:18 PM
es_squared's Avatar
Default Re: Wheels sizing (DeyAinRdy4Ds)
thats fantastic information, thanks very much guys !
Old Oct 9, 2008 | 02:45 AM
ManjuGrip's Avatar
im rocking a 215/40 on 17x8s with no probs tire is a kinda stretched
matt94z
Aug 7, 2008 05:03 PM
yoorang
Mar 29, 2008 07:53 AM
Stealthbb6
Feb 19, 2007 12:59 PM
luckyfish1
Mar 25, 2006 05:28 AM
VTecLude1994
Jun 23, 2005 01:22 PM
