having problems accelerating, help!!
Old Apr 26, 2010 | 05:06 PM
oneprelude's Avatar
Default having problems accelerating, help!!
i just replaced a headgasket, had the valves adjusted. Car ran fine for like a week, now whenthe engine is hot, i would accelerate but it wouldn't go. rpm would slowly increase as if I'm towing something heavy. clutch is not slipping and no problems with idling. Help is appreciated, thanks
Old Apr 26, 2010 | 06:06 PM
skracer13's Avatar
Default Re: having problems accelerating, help!!
Is it running on all four? I would check your compression then go from there.
Old Apr 26, 2010 | 07:04 PM
slomofo's Avatar
GDD Member
Can you swap the MAP sensor with one from another Honda to see if helps any? Have you checked the timing (belt & distributor) ?
Old Apr 27, 2010 | 07:06 AM
codyh's Avatar
formerly xmod_supra
I had the same problem with mine yesterday. Then I turned around and got on it and it went fine. I would check spark plugs and cables. Compression. Etc etc.. Im doing a compression test on my lude this weekend.
Old Apr 27, 2010 | 07:16 AM
jkoni426's Avatar
sounds like the infamous h22 lag/drag. happens to mine occasionally, but just changed the fuel filter and had a valve adjustment and seemed to help a lil bit. good luck, does it happen @ ~3k rpms?
Old Apr 27, 2010 | 04:03 PM
oneprelude's Avatar
compression is about 160-180 all across. Pretty much at all rpms
Old Apr 28, 2010 | 06:29 AM
skracer13's Avatar
No codes? As mention by slomofo, check ignition system, also fuel system...
tackhammer629
Jan 18, 2012 04:44 PM
kasperxtcy
12
Jul 4, 2008 10:24 AM
lsvtechatch92
Jun 25, 2007 07:55 PM
LINKIN024
Oct 5, 2006 05:47 PM
Ahab
Sep 4, 2002 12:16 PM
