HELP!!!: Camshaft position sensor (range/performance) CEL...???
Old May 10, 2010 | 08:30 PM
Seroga415's Avatar
Icon3 HELP!!!: Camshaft position sensor (range/performance) CEL...???
I got a 98 prelude, non sh, took it to get my transmission repaired, then all of a sudden the vtec never engaged, so i checked my numerous CEL's, and this new one popped up: Camshaft position sensor (range/performance)...??? What the hell does that mean, how do i get my vtec back and running, what will it cost, or is there just maybe a fault in the wiring, where is it located, diagrams would be great!?
Thanks guys!
______________________________
98 Prelude (auto-tragic)
aem v2 intake
ngk wires/iridium plugs
hawk hps brake pads
Old May 10, 2010 | 09:46 PM
oneprelude's Avatar
Default Re: HELP!!!: Camshaft position sensor (range/performance) CEL...???
if I'm not mistaken, it is in your distributor
Old May 10, 2010 | 10:21 PM
TheCirclingSky's Avatar
What code(s) is it throwing... P0341 etc. ???
Old May 11, 2010 | 03:27 AM
Seroga415's Avatar
Post Re: HELP!!!: Camshaft position sensor (range/performance) CEL...???
yep....the vtec doesnt engage, and as i accelerate to 5000rpm, needle slows drastically, and stops after it reaches around 6500rpm...
Old May 11, 2010 | 10:40 AM
OnyxXx360's Avatar
yeah the cyp sensor is in the dizzy, take off ur cap and rotor, and inner cap, look for loose screws excessive build up etc, i had a cyp cal go off and i found a loose screw magnatised to my sensor, now runs fine, remember to always reset ur computer and reprogram from a cold start let fully warm up, turn off, do it again. but u know all that
Old May 11, 2010 | 11:04 AM
Kronn 98SH's Avatar
There are an FAQ and Search feature for a reason.
https://honda-tech.com/forums/showthread.php?p=38252637
Old May 12, 2010 | 01:33 AM
Seroga415's Avatar
ill do it once i get my car back from the shop, thanks for the help people!
Old May 30, 2012 | 02:03 PM
dunckeldust93's Avatar
i know this is old.. but i dont even know how to make a new thread? help with that too?
i have a 98 prelude base 129k miles threw code for cam sensor no signal..my vtec engages nicely, i need a vlave adjustment sometime soon. (when i get a chance) and my dizzy is clean inside of build up and everything is tight. i reset it just now and am waiting to see what happens. i am very mechanically inclined and can replace it if needed but ive never done it before. so maybe a link to a thread also showing how to if i even need to ?? why does my vtec workwith that cel? thanks for reading.
Old Jun 16, 2012 | 07:57 PM
dunckeldustin's Avatar
hey anyone still reading this thread??
im kind of new.. idk how to start a new post?
my cel came back... im scared! im forced to drive this car to work and such.
every once in a while it just randomly shuts off... i can just crank it and it starts back but its freaky. never takes more than 2 times to get it going again but i do it rooling so no one even notices, i really want to fix this. please help?
HOOK IT UP
THANK YOU
Seroga415
May 13, 2010 12:14 PM
bukfuddie
May 3, 2006 08:10 PM
bukfuddie
Apr 16, 2006 12:49 PM
dcrbin22
May 20, 2004 05:50 AM
stehigs321
13
Mar 18, 2004 05:10 AM
