throwing code 20 and 23 on my 4th gen
Old May 16, 2010 | 01:09 PM
xtwiztidbatm4nx's Avatar
Default throwing code 20 and 23 on my 4th gen
Alright so i have tried lots of things to fix my problems so i thought i would ask on here. I have a 93 si that i swapped a h22a1 into. it is bored and sleeved also has a skunk 2 pro series intake with some bolt ons using the h23 wiring harness. anyways i have changed the knock sensor and it did not help. i then started throwing code 20 when i replaced it.when it is cold it starts to cut out like a hiccup. then when its warmed up it will do it ramdonly until it throws a check engine light then it stops. can anyone help. i heard that if you start to add lots of bolt ons it will throw the codes until you chip the ecu. any advice will help thanks
Old May 17, 2010 | 04:59 PM
Default Re: throwing code 20 and 23 on my 4th gen
I also wanted to know if im correct but is the black box by the ecu the pgm fi relay?
mattb145
Sep 17, 2008 05:01 PM
jchrm80
Feb 6, 2008 02:18 PM
alextec
Mar 18, 2006 01:26 PM
92-h23a1
Apr 19, 2003 01:17 PM
bumpin_bass
Dec 17, 2002 06:53 PM
