IACV problem
Old May 5, 2010 | 10:56 AM
Skwaro's Avatar
Default IACV problem
My setup:
H22
Mahle Gold CR11,5 87.25
Eagle rods
Kaizenspeed balancer shaft eliminator kit
Clutch - Exedy Racing Stage I
Flywheel - Fidanza 8lbs
New oil and water pump
All gaskets new - OEM
Skunk2 Pro Stage 2 camshafts
Supertech springs and retainers
Skunk2 Pro Titanium cam gears
stock valves
Stock OBD2 intake with no butterflies, 2 Blacktrax spacers
Omni Power 70mm TB
OBD2 IACV cleaned
Idle regulation done with IACV disconnected
ECU - OBD1 P30, tuned
No FITV
Problem:
Engine was dying on idle, IACV compensation is set to 40% to avoid dying (dies on idle with lower compensation). With IACV disconnected idle is fine.
However pressing brake, switching on A/C or anything consuming power causes RPM to bump to 2500RPM.
TB has no idle screw, regulation done with butterfly blocking screw.
Opening butterfly in TB more than now is not a solution - causes RPM waving.
Any ideas how to solve the problem? How to deploy more air to the intake on idle?
Old May 5, 2010 | 03:20 PM
su8854's Avatar
Default Re: IACV problem
aftermarket tbs are crap. my sk2 is like that too, i just plugged the iacv hole with liquid gasket and set my butterfly blocking screw to 800-1000rpm idle... runs MUCH better
Old May 7, 2010 | 03:39 AM
Skwaro's Avatar
Disabling IACV will cause a lot of problems during winter...
I'm going to connect IACV from OBD1 intake and test it, I heard that it's different that the OBD2 one...
beatontheeznutz
Aug 9, 2012 08:17 PM
civicek3
Feb 22, 2010 07:42 AM
Mfoehrkolb
Nov 27, 2008 09:17 AM
UK_Luder
Jul 24, 2007 09:08 AM
civicsi0721
Jun 20, 2006 09:35 AM
