H22A question
Old May 21, 2010 | 02:27 PM
antivic's Avatar
Default H22A question
What's up prelude fellas. I was wondering if you guys know the Honda part numbers for the basic tune for a Jdm h22a like water pump, timing belt, balancer. And also if you guys can give me more info on what else I should get I'd greatly appreciate it thanks!
PS I looked it up but the some forums say different part numbers and I do not want to get stuck with the wrong part number , again thank you!
Old May 21, 2010 | 02:52 PM
jlude90's Avatar
Default Re: H22A question
Dude I have no clue what you're asking for.
Old May 21, 2010 | 02:59 PM
oneprelude's Avatar
he is asking for the part numbers of the water pump, timing belt, ......
I would recommend the dealership
Old May 21, 2010 | 03:05 PM
antivic's Avatar
I went to the dealership they gave me nonsense saying you can't use usdm parts on a Jdm motor :x
Old May 21, 2010 | 03:07 PM
antivic's Avatar
Don't be that guy.
Old May 21, 2010 | 04:17 PM
92civlude's Avatar
The dealer is totally wrong. You probably got some burnt out parts guy who hates helping people. If your JDM motor is OBD1, get parts for a 94 VTEC prelude. Everything is the same except for the dist cap. Use a dist cap for a 90 accord. It has an internal coil just like JDM.
Old May 21, 2010 | 04:25 PM
minilogoguy18's Avatar
I'd do the rear main seal, dizzy o-ring and either reapply hondabond to the cam cap or if it looks worn replace it. These along with the usual t-belt, dizzy cap and rotor, water pump, plugs and wires.
Old May 21, 2010 | 04:48 PM
antivic's Avatar
Thanks for the extra info guys and I know the parts guy was full of **** but anyone know the part numbers I'll just order online
Old May 21, 2010 | 06:27 PM
antivic's Avatar
Bump bump bump
Old May 21, 2010 | 06:31 PM
bb6envy's Avatar
hondapartscheap.com will have a complete schematics for you to use to figure out what parts you need. plus they ship out extremely fast.
Old May 21, 2010 | 08:07 PM
coolboardr's Avatar
I sometimes use Majestic Honda to get parts. Doesn't take long for parts to arrive either.
http://www.hondaautomotiveparts.com/...artsSearch.jsp
Old May 21, 2010 | 09:25 PM
Kronn 98SH's Avatar
http://www.sanleandrohonda.com/parts/index.htm
Sometimes this site is cheaper than Majestic since Majestic charges a metric ***-ton for S/H. So depending on the size of the part and the total price, SLHonda is usually cheaper.
Old May 22, 2010 | 08:30 AM
antivic's Avatar
But which model should I use for an h22a it's either base, s , sh I don't want to get stuck with the wrong part!!
Old May 22, 2010 | 09:55 AM
Kronn 98SH's Avatar
It varies depending on the part.
Old May 22, 2010 | 10:42 AM
antivic's Avatar
Bumppp I wanna finish this thing!!
Old May 22, 2010 | 10:45 AM
antivic's Avatar
I know! Lol that's what the point of this whole post loll I need the part numbers for the ware pump timing belt and the balancer!
Old May 22, 2010 | 10:54 AM
Kronn 98SH's Avatar
Chances are that those parts are universal. Go to the website I provided and find out.
Old May 22, 2010 | 04:45 PM
antivic's Avatar
Dude that's what I've been trying to find out. There are 4 part numbers with more or less teeth on the water pump someone helppp me out
Old May 22, 2010 | 08:01 PM
antivic's Avatar
Bump bump bumpp
Old May 23, 2010 | 12:56 PM
antivic's Avatar
Bumpppppp
Old May 23, 2010 | 01:04 PM
gstrudler's Avatar
19200-P13-003 - same p/n for the h22a1 and h22a4 water pump, I can almost guarantee you it's the same for your h22a. Don't know where you're finding multiple/different part numbers.
Old May 23, 2010 | 02:35 PM
jlude90's Avatar
Yeah, the JDM and USDM H22A, A1, and A4, any H22 all use the same water pump, oil pump, timing belt, balance belt, everything. A4s use a different balance gear than H22a1s and older H22As but US and JDM are all the same, for the years.
H23 uses different cam gears, crank gears, timing belt, and water pump, but everything else is the same. Just order everything for a 95 SI VTEC
Old May 24, 2010 | 07:37 PM
gstrudler's Avatar
a1 and a4 have different oil pump housings due to the crank angle sensors needed for OBD2 if I'm not mistaken.
Old May 25, 2010 | 08:40 AM
jlude90's Avatar
You are correct, the pumps interchange, and an OBDII (A4) pump can be used on an older OBDI model, or an OBDI converted 5th gen, but an OBDI pump cannot be used on an OBDII car.
hector85
Sep 22, 2014 05:39 AM
brotherparker
Jun 1, 2009 04:36 PM
401tuner
Nov 20, 2007 01:02 PM
alleyezonme
Jun 14, 2004 08:54 PM
