blow by help
Old May 23, 2010 | 08:21 PM
kmeng's Avatar
Default blow by help
i have a h22a4 and it spits out oil from the breather. i was thinking it has bad rings, BUT compression test it and the cylinders read 190, 185, 180, 180. im using rc 310cc injectors with a untuned virgin p28 ecu(for now) since thats the only ecu i have that is compatible with the motor. tried chipping another p28 ecu to a h22 basemap but it lags ALOT. if anyone knows what is causing this PLEASE HELP!! thanks
Old May 24, 2010 | 05:28 AM
Quan_97SH's Avatar
Default Re: blow by help
You can have bad oil rings and still get good compression. Did you check your pcv and make sure it's not stuck?
Old May 24, 2010 | 01:26 PM
kmeng's Avatar
o yea? i thought it was the pcv too so i replaced it and it still does the same thing. maybe i can run a catch can?
Old May 24, 2010 | 02:42 PM
Apex1972's Avatar
well its probably unrelated,but an untuned P28 is not good for an H22.
Old May 24, 2010 | 03:29 PM
jprelude92's Avatar
your ring langs are starting to crack and eventually your gonna have a lot of blow by thats how my started after i added the turbo and didnt tune the car i used a piggy back, your gonna need new pistons and make sure you get it tune
Old May 24, 2010 | 09:26 PM
MikeLuder's Avatar
cheap fix, "Engine Restore 4cyl" or "cd2" @ parts store.
Tuning even stock motor helps.
mine are bad too : (
Old May 24, 2010 | 09:52 PM
kmeng's Avatar
yea i know an untuned p28 isnt good but thats all i got right now until this friday. and MikeLuder, have you ever used that stuff before? does it really work?
Old May 24, 2010 | 11:09 PM
MikeLuder's Avatar
obviously, yes. and an untuned p28? seriously? =/
Old May 25, 2010 | 04:09 AM
jprelude92's Avatar
engine restore is not gonna fix broken ringlangs maybe bad rings but not ringllangs
Old May 25, 2010 | 08:34 AM
kmeng's Avatar
thanks for the info jprelude92. i added the 4 cylinder engine restore and installed my own diy catch can. i drove it like i normally do and it doesnt seem to spit oil anymore from the breather to the catch can, but there is still a tiny bit of air blow out from the other side of the can tube that connects to the intake. any inputs?
Old May 28, 2010 | 10:03 AM
kmeng's Avatar
ttt
jerryscherry
Dec 25, 2010 12:45 PM
slowsleeper
Aug 26, 2005 07:30 AM
slowsleeper
Aug 25, 2005 11:49 AM
Tinker219
Aug 6, 2003 07:16 PM
prjctCIVIC
Jun 9, 2002 02:57 PM
