NEED HELP ASAP!!!
Old May 9, 2010 | 01:47 PM
h22a1preludeS's Avatar
Icon3 NEED HELP ASAP!!!
heres my problem. i have a 92 lude S with a h22 swap. the check engine light has been coming on right away and stayin on. wont kick vtec at all and it bogs out. alotta power loss. when i plug the jumper wire in it wont shoot out a code at all. just stays on. reset the ecu(obd1) and immediantly came on again. can anyone help me figure out away to get a code so i can fix this???
Old May 9, 2010 | 02:27 PM
gstrudler's Avatar
Default Re: NEED HELP ASAP!!!
Take it to an autoparts store and have them run an OBD scanner on it (usually free). I'm guessing your ecu is chipped since you can't get the flashing codes.
Old May 9, 2010 | 02:48 PM
fasthatch95's Avatar
Does it not let you redline or redline when vtecs supposed to come on?
Old May 9, 2010 | 04:26 PM
minilogoguy18's Avatar
He already said no VTEC which will happen any time the CEL is on. When you jump the service check connector the car should be off when jumping and then turn the key to ON and it will flash codes.
Old May 10, 2010 | 05:45 AM
nus_dogg's Avatar
Is the ECU a JDM or USDM ECU??
Old May 10, 2010 | 09:05 AM
Kronn 98SH's Avatar
That is SO not true.
Old May 10, 2010 | 06:45 PM
the car will redline but wont kick vtec. ill check that obd scanner and ive tried the shutting the car off plugging the connector in also and that didnt work. how do u tell what kinda ecu i have(first project lol)
Old May 10, 2010 | 08:38 PM
Seroga415's Avatar
https://honda-tech.com/forums/honda-prelude-4/help-camshaft-position-sensor-range-performance-cel-2774490/
I am having a similar issue...check my post
Old May 11, 2010 | 04:05 PM
oh and yes my ecu is chipped..if that helps
Old May 11, 2010 | 10:16 PM
dbd6604's Avatar
What ECU are you using? Also, did you wire up VTEC when you did the swap? Just wanna make sure...
Old May 13, 2010 | 12:28 PM
jus a obd1 and yes vtec used to pull extremely hard. now that the cel is on it wont..
Old May 13, 2010 | 12:33 PM
Kronn 98SH's Avatar
Originally Posted by h22a1preludeS
jus a obd1
More info needed here. Which ECU is it? Give the # and market.
Old May 13, 2010 | 07:18 PM
dbd6604's Avatar
jus a obd1
We're gonna need a little more than that... P28? P72?
Unphzd
75
Dec 16, 2010 08:27 AM
J240sx
11
Jan 11, 2010 06:06 PM
89eFRACER
12
Apr 13, 2006 09:21 PM
PhatwhipsJDMkits
Nov 27, 2004 11:47 PM
Metal_SOL
Jul 16, 2002 10:23 PM
