Check Engine Light Doesnt Work
Old May 19, 2004 | 03:07 AM
jeffro d's Avatar
Default Check Engine Light Doesnt Work
After failing an echeck I found out the o2 sensor doesn't work and the check engine light is not working. I replaced the o2 sensor and the bulb in the check engine light with a known working one. I reset the computer by pulling the clock fuse (per chiltons manual) and had the computer checked at AutoZone. No codes showed up, but the check engine light will not come on when the car starts. That was enough to fail echeck again. Shouldn't the light come on for a couple of seconds when the car is started?
96 Prelude si
all original
Old May 19, 2004 | 03:23 AM
Behan's Avatar
Default Re: Check Engine Light Doesnt Work (jeffro d)
yes the light should come on when the car is started ( or turned to ign, when all the other dash lights come on). You need to check the wiring for the light, use your manual. there should be a detailed troubleshooting procedure for it.
prwittman
Jul 13, 2018 01:00 PM
keegur
Acura TSX
Jan 10, 2009 01:33 PM
Hondacrxblk
Aug 25, 2008 10:36 AM
93gsrhatchbrid
11
Mar 31, 2006 03:26 PM
