difference between base and sh motors
Old May 13, 2004 | 06:00 PM
6thgen_H22accord's Avatar
Default difference between base and sh motors
Im thinking of buying a new long block and a guy from a local board has a 98 h22a4 sh long block, I tried the search but my question is any difference in motors from base and sh or is it only in the tranny and the suspension of the car?
Old May 13, 2004 | 06:08 PM
Kal's Avatar
Kal
Default Re: difference between base and sh motors (6thgen_H22accord)
you'll need to modify the blook to receive the longer driveshafts of the base motor. it's much less hassle to buy a base a4 block.
Old May 13, 2004 | 06:13 PM
ok thanks thats all i needed to know, i have done enough moding when i did the motor swap the first time, also how can you tell if its a sh or base model
Old May 13, 2004 | 06:23 PM
Kal's Avatar
Kal
Default Re: (6thgen_H22accord)
sh block has a "P5P" stamped onto it, I believe; someone confirm.
Old May 17, 2004 | 03:19 PM
anyone else, also how will the axles be different im gona be using a base 5 speed tranny not type sh tranny.
Old May 17, 2004 | 06:09 PM
Gerhard_001's Avatar
Ok here are the differences between the motors: SH oil filter location is accessable from the top the Base is in the typical location (that is it for the physical differences in the motors), and the transmissions are different, and suspensions of the two Preludes are different. These are the only differences, you do not need to modify the block to recieve driveshafts from the base, how did that come up? The base tranny will bolt right up to the SH block, since you are going to be swapping in the motor and it will already be out you can just bolt it up and proceed with the swap just like you would with any other Accord H22A swap. The only time you get into modification is if your are going to drop ATTS off an SH which I am not going to get into. The engine codes for the Blocks are both H22A4 the transmission code is how you tell an SH from a base.
Old May 17, 2004 | 06:41 PM
ok i diddnt think there was any real difference is the blocks, i knew the tranny was different and the chassis too. I was a lil confused about that driveshaft issue so i had to get more input, thanks
Old May 17, 2004 | 08:39 PM
sharkcohen's Avatar
http://ian.clendaniel.net/gallery/noatts?page=1
https://honda-tech.com/zerothread?id=640298
https://honda-tech.com/zerothread?id=621585
https://honda-tech.com/zerothread?id=496975
connvict
Nov 3, 2004 11:38 AM
phat_gsr98
Feb 19, 2004 09:39 PM
datap1mp
Oct 26, 2003 09:35 PM
black_sh
Mar 20, 2003 05:08 PM
Wo-Nelly
Dec 1, 2002 01:08 PM
