Oil Pump Difference
nope. unless you can find a way to plug the holes in the OBD II pump. and ensure that the sensors you need are going to come from the distributor. and even then, i've found that the signal sent by each set of sensors is just slightly different. still within the correct paramenters, just not quite so spot on, so i'm not sure how it will work for you.
yes it will work, I have a similar setup an a '94 hatch, disconnect the OBDII sensors and buy a OBDI distributor and connect the wires that normally went to the pump side and connect them to their correct sensor in the distributor
