Cel problems.
Old May 18, 2004 | 10:01 AM
Nocide_Eluded's Avatar
Default Cel problems.
I just checked for Cel n' the code pop up. 43, 64 and 78. I know 78 is ATTS, I heard 43 is PGM-FI Communication line but what the hell is that?
I dunno what is 64, I know it's because of my test pipe. Anybody can help me on those. Does those cel codes pop up when u run test pipe or is it just me? Im about to order a new cat so I can go pass smog. I need help ASAP. Thanks
Old May 18, 2004 | 05:50 PM
SKDRCR's Avatar
Default Re: Cel problems. (Nocide_Eluded)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocide_Eluded &raquo;</TD></TR><TR><TD CLASS="quote">I just checked for Cel n' the code pop up. 43, 64 and 78. I know 78 is ATTS, I heard 43 is PGM-FI Communication line but what the hell is that?
I dunno what is 64, I know it's because of my test pipe. Anybody can help me on those. Does those cel codes pop up when u run test pipe or is it just me? Im about to order a new cat so I can go pass smog. I need help ASAP. Thanks </TD></TR></TABLE>
i don't believe there is a code 64, just 63 and 65
you should check them again
Old May 18, 2004 | 09:04 PM
Default Re: Cel problems. (SKDRCR)
Yeah i checked it, I was wonderin which yellow light flash? When i check my for cel, My ATTS is the one thats' flashin. Is it suppose to be the ATTS that flash or should it be the check engine light. Cuz my check engine like just stay on but doesn't flash.
Old May 18, 2004 | 09:49 PM
SKDRCR's Avatar
how are you checking it?
you have to stick a paper clip into the connector
in order for the check engine light to
throw a code at you.
Old May 18, 2004 | 10:29 PM
I use a wire to the connector to short circuit it. This is how they show it on toronto prelude site.
cfran55
Jun 13, 2009 09:16 AM
crazyguy
Aug 19, 2007 10:01 PM
LunchboxZT
Feb 9, 2007 02:09 PM
JDMsocalcivic
22
Feb 4, 2006 07:54 AM
Nocide_Eluded
May 24, 2004 06:12 PM
