Upper Ball joint
Old May 13, 2004 | 08:32 PM
92LudeSI's Avatar
Default Upper Ball joint
Ok I read in my piece of **** Chilton manual that my upper ball joints in the front are not removable and to replace them I need to get a whole new control arm. I have a camber kit that supposivly is supposed to work in 92-96 ludes its obx balljoint type(If you couldnt guess. Anyways is there anyway to make it work? Someone told me I could press the stock ones out. By the way one is shot if that makes a difference. Thanks for your help.
Old May 14, 2004 | 01:03 AM
Tomservo's Avatar
Default Re: Upper Ball joint (92LudeSI)
Guys on here have pressed out there own ball joints, and now that I think about it, it doesn't seem that hard. Search for more info on DIY Ball Joint Removal. When I had to change my ball joints, I just took my control arm off, took it to a machine shop along with my new ball joints, and they pressed the old ones out and the new ones in for me. Took all of 2 hours, including the drive to NAPA's machine shop. Cost:30 bucks, as opposed to something like 300 for a new control arm or something.
Old May 14, 2004 | 01:19 AM
wstef's Avatar
Default Re: Upper Ball joint (Tomservo)
The ball joint can be pressed out, but what are you putting back? A legend one? An older generation prelude one?
Old May 14, 2004 | 01:42 AM
pentaq's Avatar
Default Re: Upper Ball joint (wstef)
This:
http://www.spcperformance.com/....html
Old May 14, 2004 | 11:46 AM
92LudeSI's Avatar
Yes i have an adjustable ball joint camber kit it was cheaper getting that than 250 for a new control arm.
themtn
Honda Civic (2001 - 2005)
Mar 26, 2010 03:01 PM
G2_Fella
24
Jun 16, 2009 03:20 PM
matryx
Jul 25, 2008 09:14 PM
digitalayon
Suspension & Brakes
Dec 19, 2005 05:26 PM
Frosty_spl
Oct 29, 2002 11:05 AM
