CASTER forward or backwards?
Old May 14, 2004 | 06:37 AM
OTT's Avatar
OTT
Default CASTER forward or backwards?
On my front left wheel my Caster is -0.12* (degrees).
Spec is MIN 1.40* MAX 3.40*
So is this Caster measurement indicating the front left wheel is too far back in the arch?
Old May 14, 2004 | 06:42 AM
OTT's Avatar
OTT
OK after doing a bit of research the Caster is the tilting of the front steering axis either forward or backward from vertical, as viewed from the side of the vehicle.
When the axis is tilted backwards (as it should be within above specs) from vertical, caster os positive. This creates a trailing action on front wheels. When Axis is tilted forwards (i.e wheel too far back within arch), Caster is negative, causing a leading action on the front wheels (i.e. pulling to one side)
Old May 14, 2004 | 08:22 AM
speedracer9k's Avatar
is there a question for this post?
Old May 14, 2004 | 02:12 PM
user 9782082308's Avatar
Default Re: CASTER forward or backwards? (OTT)
I'm wondering too. Caster is cool. I gots mine at -3.5 on my 4g. Its turn in is much nicer and doesn't make the car any twichyer than before on the highway. I'm thinkin of going to -4 next time.
Old May 15, 2004 | 01:58 AM
OTT's Avatar
OTT
The question is in the first post but I answered it in the second after a bit of searching
audsyn
Jul 30, 2009 02:57 PM
G2_Fella
May 8, 2009 08:38 AM
sk8shorty012
Feb 9, 2007 11:08 AM
ocram
Dec 8, 2004 07:17 PM
Flux
Jun 21, 2003 07:24 PM
