idle problems.. err yea.
Old May 19, 2004 | 11:27 AM
GaRn's Avatar
Default idle problems.. err yea.
ok my car idles fine the other day, two days later i start it up.. its idling at 3,000 rpms... uhhh weird huh?
only thing i can think of is i messed up the MAP sensor when spraying carb cleaner through the intake pipe... is the sensor part of the throttle body?
****** ****. more money i dont have to fix this damn car!
Old May 19, 2004 | 11:55 AM
Sephro's Avatar
Default Re: idle problems.. err yea. (GaRn)
Is it idling at 3k constant? Or does it blip at all?
Check your vacuum lines first off. Map is not in the intake it's on the firewall. But doesn't mean it isn't messed up.
Old May 19, 2004 | 01:41 PM
GaRn's Avatar
it idles at 3k constant, where is the sensor for the MAF/MAP? it might be my pcv valve but i replaced it a couple days ago already.. ill check some more.. any other ideas?
Old May 19, 2004 | 02:05 PM
SKDRCR's Avatar
Default Re: (GaRn)
i seriously doubt it would be your pcv valve,
i've never heard of a pcv valve causing those kind
of idle problems.
Old May 19, 2004 | 05:16 PM
GaRn's Avatar
yea it wasnt anything, just my own fault.. i was tightening up(taking out slack) the throttle cable, and took a LITTLE bit to much out of it ahaha...
the reason i thought it was the pcv valve maybe was because when i was running seafoam through a vacuum source, i tried the pcv valve, and when i disconnected the hose the idle shot up really high... i ended up using the brake booster but thats why i was thinkin pcv...
Old May 20, 2004 | 04:21 AM
BB2H23A1
Guest
Posts: n/a
Default Re: (GaRn)
you are an idiot
Old May 20, 2004 | 09:29 AM
SKDRCR's Avatar
Default Re: (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">... i ended up using the brake booster but thats why i was thinkin pcv...</TD></TR></TABLE>
That's where you should have originally put it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB2H23A1 &raquo;</TD></TR><TR><TD CLASS="quote">you are an idiot </TD></TR></TABLE>
please take these comments to the kills section
Justinmnhall
22
Sep 6, 2013 03:40 PM
jordan reynolds
Oct 18, 2010 10:39 PM
I Like Hondas
Jun 11, 2006 05:35 PM
mikeunreal
Oct 26, 2005 05:31 PM
paul93sir
Feb 5, 2004 11:26 AM
