3rd gear
Old May 20, 2004 | 03:04 PM
91_2.0_Si's Avatar
Default 3rd gear
well, when i shift into 3rd gear, it grinds, but its not always, only when i shift into 3rd at 3000 RPM or more, when i shift lower, it doesnt grind...does anyone have any ideas on what this could be? thanks
-Joe
Old May 20, 2004 | 05:40 PM
kablamo's Avatar
Default Re: 3rd gear (91_2.0_Si)
your synchro is most likely finished.
all you can do is to rebuild the tranny.
unless it's really bad, don't worry too much about it. the car is 13 years old. change the tranny fluid and make sure the clutch is good and the clutch hydraulics are ok (no leaks and master cyl fine) and you've done as much as you can realistically do.
Old May 20, 2004 | 05:55 PM
91_2.0_Si's Avatar
Default Re: 3rd gear (kablamo)
yea, the clutch has 7,000 miles on it, same with the master cylinder, and the slave has about 50 miles on it, so its all pretty new, im gettin it checked out in a week or 2, so there is nothing i can do, b/c i really hate that grinding noise
Old May 20, 2004 | 06:14 PM
kablamo's Avatar
does it grind EVERYtime you shift? is there anything you can do to prevent it?
eventually you'll completely wear down the gear, and you won't have 3rd gear anymore...not cool. if everythign else in the car is ok, you might be able to find a decent tranny at the scrappers.
Old May 20, 2004 | 06:22 PM
BlownVR's Avatar
Your synocro is probably gone, my friend has to shift into 4th then back into third to get it in.. thats about the only thing i can think of.
SpyLude92's Avatar
I have used GM synchromesh on some customer cars, I have also heard of people using it in hondas a lot, I am going to use it on my 89 lude si when i change it. It helps smooth shifts a lot, But does not reverse damage. The only true fix is new synchro's.
Old May 20, 2004 | 07:05 PM
josquared83's Avatar
My 94 Prelude is doing the same damn thing... sux doesnt it? well from what i heard is before you start spending money on syncrosm, try the GM synchromesh friction modified tranny fluid. It mite work... Im going to try it in a couple days.
itr1244
Sep 29, 2014 12:52 PM
nocturnal_sol
Mar 25, 2008 04:29 PM
Mugensr
Apr 12, 2007 09:56 AM
.paul
Jan 12, 2007 12:35 PM
B18cteg
Jul 3, 2003 10:18 AM
