s-afc
Old May 17, 2004 | 06:40 PM
hOndafienD 04's Avatar
Default s-afc
would a 92 si benifit from this? right now the car is stock, but i plan on get a c.a.i. cat back, headers, and test pipe or high flow cat to start off with...
Old May 17, 2004 | 06:54 PM
91_2.0_Si's Avatar
Default Re: s-afc (hOndafienD 04)
should benefit from it, a friend of mine has it on his 95 corolla, and his car got quicker with it (though those cars have little power to begin with, so every hp you gain you notice it) im gonna warn you though, if you do get it, wiring it up is an utter biatch!
Old May 17, 2004 | 06:56 PM
turbolude92's Avatar
Default Re: s-afc (91_2.0_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_2.0_Si &raquo;</TD></TR><TR><TD CLASS="quote">if you do get it, wiring it up is an utter biatch!</TD></TR></TABLE>
Only if you suck *** and dont know what your doing. Mine was a breeze.
Old May 17, 2004 | 06:59 PM
i know what im doing as long as i have a diagram...also what settings should i have it at? any reccomended settings till i get it dynoed?
Old May 17, 2004 | 07:02 PM
Default Re: (hOndafienD 04)
Mine was set at -35% across the board. But i run turbo. I would just install it the day before you get in dynoed and then just not make any adjustments. Do the initial setup but dont adjust the settings.
Old May 17, 2004 | 07:03 PM
ok...thanx for the adivce!!! anything on the wiring and stuff?
also is that header in your sig new?
Old May 17, 2004 | 07:06 PM
you can get the diagram off of Apexis website. I will get it up here asap for you. No the header is not new. It has been used for a year and would actually let it go for 110 shipped.
Old May 17, 2004 | 07:09 PM
aiight thanx, cuz i tried to d.l it but my compis being dumb....umm if you still have it in about a month...i will deff purchse it from you...don't have money now...prom killed me :-(
Old May 17, 2004 | 07:47 PM
LudaMan's Avatar
Look what I can do!
Prelude aftermarket headers are ****. I would just leave that stock for right now.
Old May 18, 2004 | 04:10 PM
Default Re: s-afc (DarkCivic2k3)
The H23 has a more restrictive header and by buying a header for this cheap would have its benefits.
Old May 18, 2004 | 04:44 PM
yeh i agree...the lude with h23 on import tuner ,made like 7 horses....and it had 240,000 miles
VSM_EJ8_408
Feb 9, 2008 08:15 AM
blks2k3
Nov 11, 2005 04:57 PM
Tommy1223
May 30, 2005 10:12 AM
BlackTypeR420
May 23, 2004 02:22 PM
1990hondaHF
Apr 10, 2003 12:30 PM
