Ring Gap
Old May 18, 2004 | 05:14 AM
93H22ACX's Avatar
Default Ring Gap
What is the best piston ring gap when building the h22 motor?
I want it tight for better compression but dont want it to smash into each other either.
I have Wiseco pistons with rings...11.9-12.1 compression ratio after .025" milled
Old May 18, 2004 | 08:35 AM
fastludeh22's Avatar
Default Re: Ring Gap (95PRELUDEVTEC206)
they didnt come w/a spec sheet?
if not i have endyne/wiseco pistons w/endyne spec sheet...i can tell you what it says
Old May 18, 2004 | 08:37 AM
93H22ACX's Avatar
Default Re: Ring Gap (fastludeh22)
please do tell me....
the pistons came with papers but nothing about ring gaps and how much to bore the cylinder walls to...
Old May 18, 2004 | 09:06 AM
whats the bore?
Old May 18, 2004 | 09:23 AM
93H22ACX's Avatar
stock bore size of 87mm...
I'm installing new darton sleeves and need to know what is min. and max bore size they recommend
Old May 18, 2004 | 10:09 AM
well this is off my old spec sheet..if i find the new one ill tell you if its different:
piston to wall clearence:
na:.0030"
fi: .0031-.0032"
ring gap:
.014-.015"
Modified by fastludeh22 at 6:23 PM 5/18/2004
Old May 18, 2004 | 10:31 AM
93H22ACX's Avatar
thanks! I appreciate it man!
Old May 18, 2004 | 10:58 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">well this is off my old spec sheet..if i find the new one ill tell you if its different:
na:.0030"
fi: .0031-.0032"
ring gap:
.0014-.0015"
did you mean:
NA:
0.030"
ring gap:
0.014" - 0.015"?
Old May 18, 2004 | 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PRELUDEVTEC206 &raquo;</TD></TR><TR><TD CLASS="quote">
did you mean:
NA:
0.030"
ring gap:
0.014" - 0.015"?</TD></TR></TABLE>
yep, fixed....i wish i had the newer sheet...
Old May 18, 2004 | 02:29 PM
SKDRCR's Avatar
hmmm, i thought most places wanted you to send the pistons in
with the block so they could bore it to exact specifications
Old May 18, 2004 | 04:55 PM
93H22ACX's Avatar
Default Re: Ring Gap (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, i thought most places wanted you to send the pistons in
with the block so they could bore it to exact specifications </TD></TR></TABLE>
yes that is true....but if you dont have the spec sheet...how would you know
called wiseco...specs for na with darton is...
piston to wall = 0.0035"
ring gap=0.012"-0.015" or 0.017"...got to look at my email again...
thanks!
user 98292739
Aug 15, 2009 07:26 PM
K-Spec
Nov 10, 2005 04:13 AM
ericrx_88
Jun 1, 2005 11:34 PM
Yambor
Apr 29, 2005 10:55 PM
Dyno Queen
Aug 26, 2003 08:17 PM
