msd cap for h22
Old Jul 23, 2004 | 12:13 PM
ebp 99 si's Avatar
Default msd cap for h22
i want to run an external coil on my h22 because my stock one keeps takin a **** on me along w/ my ignitor..but anyways i've been searching for a msd cap for h22 and the only one i can find is 1 for hitachi distributor and i talked to distributor king and mine is NOT a hitachi distributor so i was wondering which cap you guys used on your setups
any help would be greatly appreciated
Donnie
Modified by ebp 99 si at 8:18 PM 7/23/2004
Old Jul 23, 2004 | 04:18 PM
ebp 99 si's Avatar
Default Re: msd cap for h22 (ebp 99 si)
bump
Old Jul 24, 2004 | 07:38 AM
2point2's Avatar
USDM preludes come stock with external coil. That explains why you can't find one! hehe Just go to the Honda dealership to buy your performance external coil distributer cap..
H22A users are lucky.. because MSD caps suck *****!
Old Feb 6, 2006 | 03:11 AM
djnikko's Avatar
Default Re: msd cap for h22 (2point2)
Does anyone have a part number? Im from the UK and would like to check whether they have these at our honda dealerships.
If not could someone tell me the spec of prelude they got one off? year? engine?
Thanks very much
Old Feb 6, 2006 | 04:06 AM
AccordRacing's Avatar
I use a Civic Si 99-00 distributor cap on my JDM H22a. Im waiting on a clear one from Moroso now ..
Old Feb 6, 2006 | 04:31 AM
djnikko's Avatar
Default Re: (AccordRacing)
Thanks for the reply
http://www.moroso.com/catalog/...41301
They seem to be a universal fitment on the moroso site? or do they ask more info when you place your order?
Old Feb 6, 2006 | 05:37 AM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
Default Re: (djnikko)
when doing external coil to jdm h22 where do u wire up the new coil to? to the old wires?
Old Feb 6, 2006 | 01:41 PM
djnikko's Avatar
Default Re: (THC_H22 PROJECT)
You should get a DIY HT leads kit with the coil from what I remember.
You can use stock HT leads on the new cap or you can get MSD ones to match
Thanks for the replies, has anyone got a part number for the civic si 99-00 dissy cap? or the one from moroso?
Old Feb 6, 2006 | 01:45 PM
TOP END MS's Avatar
OptAuto say the Moroso cap replaces Honda Part # 30102-P57-006 & Acura Part # 30102-P72-006 .. I searched those part #s and didnt come up with anything .. Im assuming its Civic B16a2 and Integra GSR .. This wont work with all H22s .. just internal coil.
Old Feb 6, 2006 | 02:37 PM
951dc5's Avatar
Default Re: (TOP END MS)
msd is a piece of crap..i had to take that junk off my h22. rather run stock than gettin my fuel burn more often
Old Feb 6, 2006 | 07:05 PM
Layziejoe775's Avatar
Default Re: (Prelude951)
doesn't it help a little bit of everything..espically the external coil...i use a blaster 2 coil...it helps start my car real fast....stock one kind of give me trouble.....
Old Feb 6, 2006 | 11:58 PM
djnikko's Avatar
Default Re: (Layziejoe775)
Its all about what you are buidling your car for, MSD may not suit some peoples applications/projects. MSD is a good unit but there are other makes out there that are just as good and serve the same purpose.
People will tell you they will make 300-400 on a stock ignition setup, they probably make even more but for me its just that extra bit of security but you could look at it the other way and say its an extra thing to go wrong.
Old Feb 7, 2006 | 12:20 AM
PreLuDeSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">Its all about what you are buidling your car for, MSD may not suit some peoples applications/projects. MSD is a good unit but there are other makes out there that are just as good and serve the same purpose.
People will tell you they will make 300-400 on a stock ignition setup, they probably make even more but for me its just that extra bit of security but you could look at it the other way and say its an extra thing to go wrong. </TD></TR></TABLE>
true indeed
Old Feb 11, 2006 | 10:20 AM
djnikko's Avatar
Default Re: (PreLuDeSiR)
Does anyone have the honda part number for the 5 pin H22 dissy cap? Im still having no luck with this.
I need to take a feed from the dissy cap to the MSD external coil... The car is a 1994 H22a JDM
Thanks
drbenne
May 25, 2009 06:26 AM
AnclyT
Sep 5, 2007 12:07 PM
CBR
Apr 10, 2002 08:44 AM
