Won't Start Sometimes
Old Jul 25, 2004 | 04:41 PM
mdlude's Avatar
Default Won't Start Sometimes
I have a 1993 Si and sometimes when I go to turn the car on, it won't start and the gear indicator lights on the dash blink. Can anyone help me out?
Old Jul 25, 2004 | 04:45 PM
Jagan'92's Avatar
Default Re: Won't Start Sometimes (mdlude)
You have an automatic?
When you turn the key to on, do you hear the relay under the dash (above your left knee) click? If not it could be your main relay. Search for 'main relay' in prelude section to learn how to resolder the joints and maybe fix the problem.
Symptoms are as you say - when it's hot especially.
My car recently started doing that, and it would just crank and crank because no fuel was being pumped (the relay turns on the pump). Since I resoldered the joints I have had no problems.
Old Jul 25, 2004 | 05:20 PM
mdlude's Avatar
Default Re: Won't Start Sometimes (Jagan'92)
I just went out to try and start it and now its different. It won't start at all no matter how many times I try. All I get now is a very faint whirring noise. What's wrong? Yes, it is an automatic.
Modified by mdlude at 6:35 PM 7/25/2004
Old Jul 25, 2004 | 05:56 PM
mdlude's Avatar
Anyone?
Old Jul 25, 2004 | 07:17 PM
fenominal's Avatar
I had no problems until I had Circuit City install an Alpine CD Player. Now, if I pull up to refuel and I turn the ignition off but had the AC and Radio "on," and leave the Radio playing as I refill, my car (92 Si, MT) will not start. However, all is fixed if I turn off the AC and Power off the CD player.
Old Jul 25, 2004 | 07:36 PM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdlude &raquo;</TD></TR><TR><TD CLASS="quote">I just went out to try and start it and now its different. It won't start at all no matter how many times I try. All I get now is a very faint whirring noise. What's wrong? Yes, it is an automatic.
the whirring noise is your fuel pump, so rule that out as the problem
Rickdogg
Feb 18, 2012 12:26 AM
nismogrendel
Apr 24, 2010 01:43 AM
My_EFsedan
Sep 20, 2009 09:27 PM
Fuzion
20
Sep 2, 2004 07:17 PM
tboss
Sep 26, 2003 06:30 AM
