Knock sensor problems
Old Jul 25, 2004 | 05:41 PM
Red_Greddy_Si's Avatar
Default Knock sensor problems
Ok 97 lude code 23. I have done a search in the archives and found nothing relivant.(SP) This car is bone stock with the exception of springs. I have went through the Helms manual and cant figure out how to mimic the Knock sensor. I have checked continuity of the wires and they are fine. and I tested the knock sensor and it does not respond voltage wise. So what I want to know is what does the ECU want to see from the knock sensor noramally. does it want to see a ground or does it want a 5v reference or something? is there a way to trick the ecu to make it think there is a knock sensor there like with a couple of radio shack parts or what have you? thanks for all the help guys!!!
Old Jul 26, 2004 | 02:34 PM
Default Re: Knock sensor problems (Red_Greddy_Si)
wow the vast knowledge here is incredible
Old Jul 26, 2004 | 02:44 PM
mattmw88's Avatar
In addition to his question... what is the nominal life span of knock sensors? My wireing is good too, (as is my ecu), but I still but intermittent code 23... This sucks, should I try using someone elses knock sensor? TIA guys...
Old Jul 27, 2004 | 03:10 PM
Default Re: Knock sensor problems (mattmw88)
nobody here has any insight on this?????? I know on a 99Si you can put a resistor of a certain value in there to mimic it and never get a CEL
Old Jul 27, 2004 | 05:11 PM
jmcclell's Avatar
Try using a 15K resistor. Connect one end of the resistor to GROUND and the other end to the knock sensor input.
Please let me know
Old Jul 28, 2004 | 04:38 PM
Default Re: Knock sensor problems (jmcclell)
does anyone else agree with this????? I dont need to fry the ECU or anything. I dont want to be the guine pig. Top top Bumpage any more input please!!!
Old Jul 28, 2004 | 04:45 PM
01 LudeDude's Avatar
This is very crude, so take it with a grain of salt....
I don't know the answer to your question, but...I've hear more than one person say that you can get a knock sensor to trigger by taping the block with a small hammer.
I have no idea if it realy works, but since nobody else is saying anything, I figured I'd throw that out there.
SuperBowser707
Dec 4, 2012 07:49 AM
Under_Pressure
Oct 4, 2005 12:38 PM
92ludeport
Jul 8, 2005 02:08 PM
evo
Mar 4, 2003 07:10 AM
T_Rex
27
Feb 12, 2003 07:41 PM
