problems after install of new intake
Old Jul 26, 2004 | 07:56 PM
w-fries
Guest
Posts: n/a
Default problems after install of new intake
i just installed a aem short ram intake to my 1996 prelude 2.3si, the problem is when i start driving and when i stop like at a stop light our something it starts reving up to like 2,000 rpms i can't figure out why this is it will just keep reving from 1,000-2,000 rpms till i start driving again help would be much appreciated.
Old Jul 26, 2004 | 08:04 PM
94svtec's Avatar
Default Re: problems after install of new intake (w-fries)
by any small chance did you happen to move or loosen the throttle cable? If not I would check for a loose vac hose or perhaps the intake has a leak somewhere?
Old Jul 26, 2004 | 08:05 PM
w-fries
Guest
Posts: n/a
Default Re: problems after install of new intake (94svtec)
i already checked for leaks on the intake but what i dont understand what your saying about the throttle cable interferring with it.
Old Jul 26, 2004 | 08:06 PM
w-fries
Guest
Posts: n/a
o something else do u think the heat outside could have anything to do with it
Old Jul 26, 2004 | 08:08 PM
94svtec's Avatar
I was just asking to see if by some small chance maybe you kinked the cable?... If it is you idle I would check the IAC valve... do you have a Helms Honda Prelude Manual..??
Old Jul 26, 2004 | 08:10 PM
94svtec's Avatar
whoops your Idle not you idle.. my bad..
Old Jul 26, 2004 | 08:12 PM
w-fries
Guest
Posts: n/a
well i just drove around the block to see if it did it again and it stopped doing it i guess it must of been a kink in a hose but it just stopped doing it and its running fine now thats really odd
Old Jul 26, 2004 | 08:13 PM
w-fries
Guest
Posts: n/a
thanks for the help thought i pulled on one little hose that was by the intake it started acting normal then i went and drove it again i think i pulled the hose u were talkin about
thanks for the help
Old Jul 26, 2004 | 11:53 PM
vinuneuro's Avatar
i would reset the ecu just to make sure also.
Old Jul 28, 2004 | 04:44 AM
w-fries
Guest
Posts: n/a
Default Re: problems after install of new intake (vinuneuro)
ok i thought i fixed the problem and it came back when i was driving home from a friends house. How do u reset the ecu chip? and what are other things that it could be if not the ecu and how do i fix those things?
Old Jul 28, 2004 | 05:12 AM
Slipknt777's Avatar
disconnect you negative batery cable for a few minutes to reset the ECU. maybe you need to adjust your idle screw.
Old Jul 28, 2004 | 05:14 AM
Monkey Fing a Coconut's Avatar
to reset the ecu pull the radio fuse for a couple min and u can pull the - batt cable too
Old Jul 28, 2004 | 05:37 AM
w-fries
Guest
Posts: n/a
Default Re: problems after install of new intake (twistedbydezign)
this shouldn't have anything to do with the idle i just put a new intake on that shouldnt mean anything, and i have no idea where the radio fuse is, shouldn't unplugging the battery be enough?
Old Jul 28, 2004 | 07:02 AM
delguiner's Avatar
i had a very very similar propblem as you and it ended up being the fast idle valve.... careful cause when i had that problem, my IACV ended up screwing up next. I don tknow if they were related or just coincidences, but beware
Old Jul 28, 2004 | 07:22 AM
PirateMcFred's Avatar
sounds like a vacuum leak to me. search and you will find a lot of these idle threads
Old Jul 28, 2004 | 07:26 AM
w-fries
Guest
Posts: n/a
it doesn't do it every time i drive though it does it about 35% of the time so i dont know how it could be fast idle valve because wouldnt that do it a 100% of the time
Old Jul 28, 2004 | 08:20 AM
98 blacksh's Avatar
its your iacv it will happen again
Old Jul 29, 2004 | 07:59 AM
w-fries
Guest
Posts: n/a
Default Re: problems after install of new intake (98 blacksh)
ok i unplugged my negative battery for a couple of minutes then i plugged the negative battery and now i have a new problem my security system won't let me start teh car it's the stock security system that comes with preludes. i need help plz
i have no idea what hose is the ivac and i have no idea how to fix it if someone could show me a picture our something that would be real helpful.
Old Jul 29, 2004 | 10:08 AM
w-fries
Guest
Posts: n/a
my bad i think i have an aftermarket security system i just bought my lude 2 weeks ago
Old Jul 29, 2004 | 07:57 PM
w-fries
Guest
Posts: n/a
ok scratch the whole battery and security problem i fixed taht i already reset the ecu and that still didn't help. i need to know how to fix this iavc problem i dont even know which hose it is
Old Jul 29, 2004 | 08:10 PM
Hawkze_2.3's Avatar
We-todd is not letting me log in right now or I'd post a pic for you, but the IACV is on the front of the intake manifold. It has 2 coolant hoses coming off of the bottom of it and a black cylinder on it's side with a connector connected...
Old Jul 29, 2004 | 08:13 PM
Hawkze_2.3's Avatar
Default Re: problems after install of new intake (Hawkze_2.3)
Also, personally, my idle problems never had anything to do with the IACV....always vacuum leaks(IM/TB gaskets, vacuum hoses, throttle plate not closing, etc...)
Old Jul 29, 2004 | 08:15 PM
Pr0jektLude's Avatar
i have the same problem sometimes like if its cold out while the car is warming up my motor likes to vigorously rev from 1,000-2,000 rpms. I figure its a vacuum leak since i had to disconnect a hose...that has no where to lead on the new intake. they give you like a plastic plug but will that really be helping it? i thought about maybe making a small hole in my intake for it to be put back on there but i havent tryed that yet. But this could be the smae problem your having w-fries
Old Jul 29, 2004 | 08:17 PM
w-fries
Guest
Posts: n/a
Default Re: problems after install of new intake (Pr0jektLude)
i think i am going to hook my prelude up to one of those computers so i can find out the problem i remember when i bought the intake u have to take off this wire on teh front and plug it up with a rubber thing which i did, but i think ill just hook it up to a computer that should tell me the problem shouldn't it???
Old Jul 29, 2004 | 08:22 PM
PhazedSI's Avatar
it's most likely a vacuum leak. Someone above mentioned the throttle cable being to tight causing jumping idle. What happens is the throttle plate does not fully close causing a vacuum leak. Since you say it started after you installed an aftermarket intake leads me to beleive that maybe you removed a vacuum hose from the intake manifold which ran to the stock intake resonator. If you did not cap off the nipple on the intake mani for this hose then thats your problem.
