cv joint will not go in!
Old Jul 21, 2004 | 09:07 AM
killa_lude's Avatar
Default cv joint will not go in!
im trying to get the drivers side axle into the intermediate shaft, but the cv joint wont go in. i've taken off the axle nut and pounded the **** out of the axle and it still wont go in. do any of you guys have any suggestions?!
Old Jul 21, 2004 | 09:09 AM
prelittlelude's Avatar
Default Re: cv joint will not go in! (killa_lude)
you mean your trying to get the axles to slide onto the splines of the intermediate shaft?,
make sure that the snap ring isn't destroyed and lube everything up
Old Jul 21, 2004 | 09:12 AM
killa_lude's Avatar
Default Re: cv joint will not go in! (prelittlelude)
yeah im hitting the axle so it pushes the cv joint into the intermediate shaft.
i cant tell if the ring is expanded to much. where could i get a new ring?
Old Jul 21, 2004 | 10:23 AM
Sticky Tires's Avatar
* B A N N E D *
That's the worst part of replacing the CV boot. You just gotta be patient and line it up right. Make sure it's greased up good.
You can get the new ring at the dealership. I don't know if they sell individual parts.
Remember be patient or you'll F something up. haha
Old Jul 21, 2004 | 11:24 AM
killa_lude's Avatar
Default Re: cv joint will not go in! (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">That's the worst part of replacing the CV boot. You just gotta be patient and line it up right. Make sure it's greased up good.
Remember be patient or you'll F something up. haha</TD></TR></TABLE>
yeah im getting a new ring today.
Old Jul 21, 2004 | 04:19 PM
killa_lude's Avatar
ok update...the cv joint wont even go into the intermediate shaft with out a clip ring. wtf, is there something wrong with the intermediate shaft?
Old Jul 21, 2004 | 07:18 PM
killa_lude's Avatar
bump.
Old Jul 21, 2004 | 11:32 PM
Eddiebx's Avatar
let me ask you, is ur driverside axle a male inner joint? or a female one like the h23/22 axles?
if it is a male inner joint, it sounds like you the wrong axle. sounds like your trying to shove a passenger side axle into the female intermediate shaft.
if you look at the splines on the driverside axle, it should run the full length of the inner joint. if the splines are only about 1" long and the rest is smooth, then you have a passenger side axle, which wont go in even if you pound it with a sledge hammer.
Old Jul 22, 2004 | 12:43 AM
killa_lude's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">let me ask you, is ur driverside axle a male inner joint? or a female one like the h23/22 axles?
if you look at the splines on the driverside axle, it should run the full length of the inner joint. if the splines are only about 1" long and the rest is smooth, then you have a passenger side axle, which wont go in even if you pound it with a sledge hammer.</TD></TR></TABLE>
well the axle is the right one....its a female into the male IS, its the same axle that was on there before...it worked perfect.
Old Jul 22, 2004 | 08:23 AM
Default Re: (killa_lude)
try cleaning both the male and female ends, and make sure that the splines arn't all gauled up, if some how you managed to force it even part way on wrong and the splines get messed up that thing is goig to be a bitch..
and its the same axle and intermdiate shaft you had on before?
Old Jul 22, 2004 | 08:32 AM
killa_lude's Avatar
Default Re: (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">try cleaning both the male and female ends, and make sure that the splines arn't all gauled up, if some how you managed to force it even part way on wrong and the splines get messed up that thing is goig to be a bitch..
and its the same axle and intermdiate shaft you had on before?</TD></TR></TABLE>
yes same axle and IS as before.
Old Jul 22, 2004 | 01:17 PM
killa_lude's Avatar
bump...
Old Jul 22, 2004 | 04:39 PM
killa_lude's Avatar
bump bump
Old Jul 22, 2004 | 11:00 PM
Slow_Em1's Avatar
pull it out, then pull the CV boot off, then put the bearings back in. reassemble the axle then slide it back in.
Old Jul 23, 2004 | 12:16 AM
killa_lude's Avatar
Default Re: cv joint will not go in! (Slow_Em1)
the problem is with the intermediate shaft spine and the cv joint...they wont fit together for some reason.
Old Jul 25, 2004 | 11:22 PM
Slow_Em1's Avatar
pull the shaft, and axle out, connct the axle to the half shaft, then connect the half shaft to the tranny. ive had this problem before also. i think it was because the tranny wasnt in correctly ...but try it, tell us if it works
Old Jul 25, 2004 | 11:53 PM
killa_lude's Avatar
how do you think the tranny wasnt in correctly?
vistacat
Jun 15, 2007 05:11 PM
sony224422
Oct 2, 2006 09:23 PM
killa_lude
Jul 22, 2004 07:39 PM
Pearce
Oct 16, 2002 10:44 AM
4doorH22
Apr 7, 2002 08:06 PM
