What is this??
Old Nov 28, 2011 | 01:16 PM
540dude's Avatar
Default What is this??
Realized a rattling coming from under the hood and then noticed this piece is loose. What is it and how should I go about fixing this?
Old Nov 28, 2011 | 01:23 PM
Hawkze_2.3's Avatar
Default Re: What is this??
It's just a heat shield for the alternator. You can check and make sure all the bolts are tight, and if they are, try to find out where it is contacting another part and bend it away (so it doesn't rattle anymore).
Old Nov 28, 2011 | 01:34 PM
BergRacing21's Avatar
or just remove it...it's not absolutely necessary lol. but like Hawk said if you want to keep it just make sure the bolts are tight or find where it's hitting something else
Old Nov 28, 2011 | 01:38 PM
540dude's Avatar
Thanks a lot guys! Would it be bad to just remove it?
p.s. what a shitty heat shield...
Old Nov 28, 2011 | 02:32 PM
Hawkze_2.3's Avatar
The alternator is pretty close to the header, might want to keep it. It's not like your alternator is just going to fall apart, but the shield might help the internals last a bit longer.
Old Nov 28, 2011 | 02:49 PM
540dude's Avatar
Thx. I finally got the bolt in after some struggling. Tight squeeze for my hand
While I was under there, though, I noticed I was leaking a bit of oil... it looks like it's coming from right above my oil tank and beneath my oil filter.
What do I need to do to fix/ how much is it going to cost?
Old Nov 28, 2011 | 03:22 PM
Hawkze_2.3's Avatar
Google 'Prelude oil cooler o-ring'
Or Bing it...whatever floats your boat
Old Nov 28, 2011 | 03:47 PM
540dude's Avatar
You sure that's it?
Old Nov 28, 2011 | 05:53 PM
Hawkze_2.3's Avatar
You sure that's it?
Well, no because I don't have your car in front of me, but it sure looks and sounds like it. Plus it is a really common thing.
Old Nov 28, 2011 | 06:52 PM
540dude's Avatar
Thanks for all the help man
Old Nov 30, 2011 | 04:53 PM
LatnKng's Avatar
jajajaja...easy easy...but your right Hawkze!!
Dave_Dc2
Sep 12, 2010 10:20 PM
si92prelude
Jun 24, 2010 12:04 PM
JBirch_97Prelude
Nov 26, 2007 04:49 PM
dhn
Mar 25, 2006 08:48 AM
X-Static
Sep 9, 2004 10:46 PM
