Lighting problem
Old Dec 30, 2011 | 07:01 AM
Draiga1988's Avatar
Default Lighting problem
Hi I have a 97 prelude SH I am having a problem with my lights. My tail lights won't come on an my dash lights for the gauges won't come on either I changed the 15amp fuse under the dash an I have changed all the bulbs in the tail lights an they still will not come on please any information of this issue would be greatly appreciated thank you
Old Jan 2, 2012 | 12:38 PM
97ludedude's Avatar
Default Re: Lighting problem
Double check all of your fuses. If none of them are blown i would begin to suspect the headlight switch. You need to figure out where you are losing power.
Old Jan 2, 2012 | 03:45 PM
mcnos's Avatar
That problem exactly happened to me just last night, whenever I turn on the headlights, they work but running lights and speedometer light stopped working, I'm just assuming its my fuse, but I haven't checked. Will do tommorow. Also turning on my headlights also made my fuel/temp gauge dim like 70%, but now my dash light is no longer working, it no longer does that. Yay?
Old Jan 2, 2012 | 06:30 PM
Hawkze_2.3's Avatar
Might want to have your alternator tested....
Old Jan 2, 2012 | 06:47 PM
mcnos's Avatar
Well it also did it while the car is off. Not just while its running.
Old Jan 3, 2012 | 07:20 AM
specbb6's Avatar
check your fuse box (the one inside), not necessarily the fuses but the connectors. meaning unplug and plug them back in and see if theres a short somewhere. mine was/is like that and to fix it i had to tape down (secure) one of the connectors so it wouldnt come loose due to vibrations. i guess you could replace the connector if you really wanted.
my lude had your exact same problem. good luck
Old Jan 4, 2012 | 03:33 PM
mcnos's Avatar
Do you have an aftermarket radio? Could be the dimmer/power wire inside of it. That was my cause, fixed it right away.
BLU CIVIC
Dec 29, 2010 03:31 AM
213374U
Mar 30, 2008 01:17 PM
philipwk
Oct 14, 2005 06:49 AM
ChargedLude97
13
Feb 12, 2004 01:57 PM
