jumping tach
Old Nov 18, 2011 | 10:01 AM
patbb2's Avatar
Default jumping tach
ok so my tach is acting crazy. im not very good with electrical so im hoping u guys can help me. as soon as i fire it up my tach jumps usually between 2 and 6 rpm. up and down quickly. any ideas?
Old Nov 18, 2011 | 10:13 AM
H22a1Prelude's Avatar
Default Re: jumping tach
Bad distributor cap potentially. Go to autozone, buy one, pop it on. If it fixes it, there's your problem. If not, return it. Search if you want more info on the dizzy and this issue
~Peace
Old Nov 18, 2011 | 10:21 AM
patbb2's Avatar
thanks. thats a lot cheaper then i thought it was going to be. i was told it was probably a junk cluster but that just didnt sound right. ill try it out and let u know what happens..........
Old Nov 18, 2011 | 10:45 AM
Dizzy controls the revs on the tach. Bad Dizzy = Jumping Tach. That's the most common issue that people have when getting the jumping tach. Good luck and keep us up to date. Sorry I don't have more info, but the search function should help if you want to know more of a technical reason as to why it happens.
~Peace
Old Nov 18, 2011 | 02:06 PM
Anthony's Avatar
Mr. Fuch-yu
I had this same issue in my bb6. I changed the cap and rotor button, plugs, and wires to no avail. In my case, my egr valve was bad. Im not saying this to discredit anyone elses suggestions... just trying to point you in another direction if the dizzy isn't the culprit. Good luck.
Old Nov 19, 2011 | 11:12 AM
Acidcrakker's Avatar
I just run my tach off the A21-A22 ecu.
No more need for jumping tach crap
Old Nov 19, 2011 | 04:18 PM
bigblockh22's Avatar
Could very well be a bad ground if not the dizzy cap.
Kaptan
Sep 3, 2018 08:31 AM
AFAccord
Jan 3, 2006 05:30 AM
importboi22
May 31, 2004 09:54 PM
importboi22
Oct 31, 2003 05:20 PM
CLBrackin
13
Jan 6, 2003 05:45 AM
