driver side window/lock switch dont work
Old Jan 20, 2012 | 12:57 PM
hughgogh's Avatar
Default driver side window/lock switch dont work
on my 98 prelude, the driver side window and lock switches dont work? i replaced the switches and checked the fuses and still nothing? anybody know what to do?
Old Jan 20, 2012 | 02:15 PM
Apex1972's Avatar
Default Re: driver side window/lock switch dont work
is there a ground inside the door itself? sounds strange that you replaced the switch and fuse . that would lead me to believe that the door lock motor and window motor failed at the same time. thats seems unlikely as well, thats why i was wondering about a ground.
Old Jan 21, 2012 | 01:34 PM
97ludedude's Avatar
Did they both quit at the same time? You need to get a volt meter or test light in there to see where you are losing power. I don't think they would have a ground in the door, but i have never had my door panel off so i am not 100% on that. I would think that the ground would be on the chassis.
Old Jan 22, 2012 | 08:47 AM
Apex1972's Avatar
might be the connector from the inside of the car to the door harness.
Old Jan 23, 2012 | 01:51 PM
hughgogh's Avatar
i looked inside the door panel and found what looked to me like water/rust, could it be that they left the window cracked and rain fried the wiring? i bought the car with that problem already,whats got me trippin is that the driver side window works and the switch on the passenger door window works, but on the driver main switch i cant control the passenger window or door lock switch! so i have to reach over to roll down the passenger door window and auto lock switch..so right off the bat it cant be the power window relay right?
Old Jan 23, 2012 | 01:53 PM
hughgogh's Avatar
think my next move is replacing the wiring for the window switch and door lock, thanks doods for all the helpful tips, ebay time
Old Jan 23, 2012 | 02:27 PM
hughgogh's Avatar
atleast the windows and lock still have signs of life but on certain sides only..
Old Jan 23, 2012 | 02:43 PM
ludegurl's Avatar
im having the same problem with my 98 prelude hughogh my window works but i have to pull the door handle up and down and eventually it will unlock ..let me know if u get it fixed ,,have you looked for info on any of the prelude forums?
Old Jan 23, 2012 | 04:55 PM
Apex1972's Avatar
if you can source another lock actuator, try hooking it up in place of the one thats on your door. that will tel you everything. if it works, then your guess is right, water. but I have to say, I have been without the upper door molding on my driver side door for a few years now and water literally pours in and and I have no troubles. I guess if it got directly into the harness, it might have shorted those components out.keep us updated.
Old Jan 24, 2012 | 04:31 PM
nemesis25's Avatar
It's the Multiplex unit that's gone bad. Honda used a control unit or computer for the door actuators. If you have any electronics skills, simply remove the unit, it's located under the dash, and repair it by resoldering the terminals/contacts. The units are no. 12 & 13, in the attached link.
http://www.hondaautomotiveparts.com/...L+UNIT+-+CABIN
Old Jan 24, 2012 | 10:53 PM
hughgogh's Avatar
super helpful man thanks, i'll def get on that..
Old Jan 24, 2012 | 11:20 PM
hughgogh's Avatar
looked on ebay and all they have is the passeger side multiplex, gonna keep searching or maybe i can take it off and take it somewhere to resolder it for me, thanks nemesis u sure know yer stuff!
Old Jan 24, 2012 | 11:24 PM
hughgogh's Avatar
no i havent, im quite new to this forum so im still getting acquainted with it,also new with the 98 lude, just got it like in december,
scclark
Honda CR-V & Element
Aug 29, 2016 05:38 PM
1996HondaCE1
Mar 27, 2016 03:06 PM
chris4x4
13
May 8, 2011 10:39 AM
:jdmshmaydm:
Aug 31, 2010 07:34 AM
funkylemons
Audio / Security / Video
Nov 27, 2002 10:50 AM
