Heater
Old Nov 19, 2011 | 07:51 AM
LatnKng's Avatar
Icon2 Heater
I have a 92 S and no heat..the blower does blow but my heat is not working. If you guys / Gals can list a few things to check first in order for me to get going instead of wasting time on something it might not be would def be very helpful. Thank you all in advance.
Old Nov 19, 2011 | 08:32 AM
Hawkze_2.3's Avatar
Default Re: Heater
If the blower is blowing then that means you have no coolant flow through the heater core (in the dash). Check the coolant valve on the firewall and see if it opens and closes when you move the temp slider on the climate control unit.
Old Nov 19, 2011 | 08:57 AM
LatnKng's Avatar
Default Re: Heater
will do.thanks alot Hawkze..will follow up!!
Old Nov 19, 2011 | 01:23 PM
LatnKng's Avatar
Default Re: Heater
checked it..smh..my heater hose not hooked up..and my air selector switch not hooked up either to the firewall hose sector...damn...allgood. IMMA REGRET IT TOO!!!!!
Old Nov 26, 2011 | 03:11 PM
LatnKng's Avatar
Default Re: Heater
ok...i installed a coolant valve on from a 94 Si automatic, assuming that the valve shouldnt matter when it comes to the the type of transmission that is, then the hoses, hoping that they are in the right direction, and still no heat. The blower is blowing, i checked all fuses...and now im stuck..still trying to determine why its not cooling.
Old Nov 27, 2011 | 08:15 AM
LatnKng's Avatar
Default Re: Heater
problem solved..thanks again for the assist!!
andyz
Apr 6, 2022 08:14 PM
ComicConBooBoo
13
Jan 2, 2011 07:01 AM
I Am The Ghost
Feb 10, 2010 07:25 AM
hmoobthojboi07
Feb 24, 2009 12:01 PM
