need help with vtec
Old Jan 20, 2012 | 10:39 AM
darkbombers's Avatar
Default need help with vtec
honda 93 wired for vtec still getting code 22 cel, i bought a pressure switch still didnt go away i have a jdm h22. when i ground the pressure switch i lose my rpm meter any suggestions?-
Old Jan 21, 2012 | 06:07 AM
97ludedude's Avatar
Default Re: need help with vtec
are you getting any other codes or is 22 the only one? Pull the solenoid off the head and clean the screen out.
Old Jan 21, 2012 | 09:39 AM
93redcb7's Avatar
double check your pin's
Old Jan 21, 2012 | 01:42 PM
holmesnmanny's Avatar
This is almost always the pin not being correctly in the connector. There is a backing tab on the connector at the ecu, open that up and then push the pin in, then close it and reconnect the connector to the ecu. See if that works.
Critikul
Mar 1, 2012 05:54 AM
prime-R
16
Apr 11, 2009 05:33 PM
accordingtoh22
May 21, 2007 07:55 PM
lshatch92
Mar 27, 2006 10:04 AM
