Blown Motor.
Old Apr 5, 2005 | 01:41 PM
SexyH22's Avatar
Default Blown Motor.
i have a 97 prelude w/ a JRSC on my h22, an i recently did a compression test an here are my results: 135, 135, 0, 135. why are all of my numbers so low? i know that i need to do a rebuild, and a would like to know whaich parts are best for the price? also what all am i going to have to do. rods, bearings, pistons and rings probably, but do i have to resleeve it also? how much am i looking to spend? and are there other things that could be cause my compresssion to be so low? thanks.
Old Apr 5, 2005 | 02:02 PM
98TypeSH's Avatar
Default Re: Blown Motor. (SexyH22)
Depending on the damage incured you may need a rehone at best. Looks like you lost your rings on #3 and probably cracked the ringlands on 1,2,4 hence the low compression.
How long and at what psi have you been boosting ?
Worst case senerio, a set of h22 pistons with new rings a rehone or .25 over depending on damage and cylinder wall conditions + replace all the bearings while the block is apart and all matinence that would be needed ( timing belt, water pump, thermo, oil pump etc etc.)
Be sure to give all the pistons/rings a good going over with compression numbers like that.
Old Apr 5, 2005 | 02:05 PM
SexyH22's Avatar
i am running 9psi and have been for about 15k miles or so. the timing belt was changed when the sc was put on. so it is still pretty new, still change it? also would it be best to replace all the pisotns rings rods and bearings w/ aftermarket parts? and if so how much approx. to get me back on the road?
Old Apr 5, 2005 | 02:06 PM
98TypeSH's Avatar
Default Re: (SexyH22)
nah if its in good condition and there is no wear on it dont bother changing it. This is going to be a pretty in depth tear down, so find a good shop that knows what they are doing. You wont need to resleeve unless you want to drop forged pistons and up the boost.
pentaq's Avatar
Don't think so. Just review those parts for any damage or so.
Old Apr 5, 2005 | 06:00 PM
SexyH22's Avatar
so you think im best off to rehone and put factory parts back in? or build it up if i plan on staying at only 9psi.
Old Apr 5, 2005 | 07:19 PM
vinuneuro's Avatar
if he puts the h22 pistons back in, isnt he going to end with a similar problem again down the road? Youd think that he needs lower compression pistons.
Old Apr 5, 2005 | 07:43 PM
chihuahuamanx's Avatar
Default Re: (vinuneuro)
yea itd be cheaper to put in stock pistons, and i realize money is an issue with most of us, but i think in the long run making the jump to a sleeved block would really make you happier in the long run.
I could be wrong though, and i understand how $$ plays into our hobby so much, so best of luck!
Old Apr 5, 2005 | 09:31 PM
PrettyLude's Avatar
man, that is some money to fork up, you might wanna think about forged pistons and rods, and resleeving, cause it will only be a little bit more
Old Apr 6, 2005 | 08:45 AM
98TypeSH's Avatar
Default Re: (PrettyLude)
just buy a decent set of used h22 pistons and some new rings and you are set ( rehone does not cost that much compared to sleeving and the price of forged pistons) You want to do it right then build the bottom end and boost at whatever you want.
This whole having to resleeve **** is really gettin to me. There are no options but to resleeve and drop 3-5 grand depending on parts and who you know.
Old Apr 6, 2005 | 09:30 AM
SexyH22's Avatar
so you suggest rehone, and all stock parts again? if it is only my rings will i be ok only replacing them and keeping the original psitons, the motor only has about 60k on it. also if i use all oem parts again, is it likely to blow again at 9psi? cause if its gonna blow in another 50k i am going to need to do it right.
Old Apr 6, 2005 | 09:48 AM
homesauce's Avatar
Hell yea, it's gonna blow again.
If it blew after 15K once, there is a reason for it happening.
What you need to do, is rebuild back to stock and improve the tuning, or fully build your block.
Old Apr 6, 2005 | 09:51 AM
98TypeSH's Avatar
Default Re: (homesauce)
Just start saving for a crazy *** bottom end build or pull the turbo off.
Old Apr 6, 2005 | 01:38 PM
SexyH22's Avatar
its an sc.
by rebuild back to stock just meaning put all oem parts back in, and leave the sc on?
aavtec
16
Jul 3, 2013 02:22 PM
5_Lug_B
Aug 14, 2007 05:51 PM
bdpetska
Jul 18, 2006 04:12 PM
juicedricer
Jul 16, 2003 02:10 PM
Halo
Nov 6, 2001 07:34 AM
