A few problems (idle and studder)
Old Apr 3, 2005 | 05:46 PM
DarkBB4's Avatar
Default A few problems (idle and studder)
OK, after my car is warmed up to operating temp, when im at idle, it dips really low sometimes (like 600 rpm) then goes back up and down. It feels like its going to stall. So far i have a EGR block off plate, and i got a new map sensor. It still does it!!!! i have a cel for teh block off plate and ill recheck the code, but i believe its still code 12 (egr) so that souldn't be a problem.
Also, whenver i accelerat between 2k and 3k rpm, the whole car like vibrates/shakes and it is not smooth
Could htis be a clogged catlytic converter? Fuel filter?
Old Apr 4, 2005 | 12:34 PM
DarkBB4's Avatar
Default Re: A few problems (DarkBB4)
up
Old Apr 4, 2005 | 12:39 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">OK, after my car is warmed up to operating temp, when im at idle, it dips really low sometimes (like 600 rpm) then goes back up and down. It feels like its going to stall. So far i have a EGR block off plate, and i got a new map sensor. It still does it!!!! i have a cel for teh block off plate and ill recheck the code, but i believe its still code 12 (egr) so that souldn't be a problem.
Could htis be a clogged catlytic converter? Fuel filter?</TD></TR></TABLE>
you shouldn't have a CEL if all you have is a block off plate, if you removed the egr completely then thats a problem right there. you need to leave the egr valve in place other wise the car freaks. start by putting your egr bolted over the block of plate , with everything plugged in normal.
possibly take you IACV off an get some carb cleaner and clean that out. but start by getting rid of the CEL and then reseting the ecu
xd69
Apr 13, 2008 01:35 AM
Race Egr
Apr 5, 2004 10:32 PM
Race Egr
Apr 4, 2004 08:48 AM
baonest1
Aug 17, 2003 05:51 PM
Prevail
Feb 26, 2003 05:57 AM
