Normal oil pressure
Old Apr 4, 2005 | 06:46 AM
RemerLex11's Avatar
Default Normal oil pressure
My oil is at the normal level for my H22 and my oil pressure gauge has been reading about 65psi at 3k rpm and about 15psi at 700rpm someone told me that was a bit low so what's normal?
Old Apr 4, 2005 | 07:32 AM
95PreludeSi's Avatar
Default Re: Normal oil pressure (Matt5745767)
I just put a H22A into my 95 Si. Those readings are pretty close to my car. I say your ok.
Also, I get to 75ish at WOT
Old Apr 4, 2005 | 12:52 PM
Monkey Fing a Coconut's Avatar
Default Re: Normal oil pressure (95PreludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">I just put a H22A into my 95 Si. Those readings are pretty close to my car. I say your ok.
Also, I get to 75ish at WOT</TD></TR></TABLE>
Old Apr 4, 2005 | 02:36 PM
red92si's Avatar
Spec is:
No less than 7psi @ Idle
No less than 50psi @ 3000rpm
Old Apr 4, 2005 | 03:58 PM
RemerLex11's Avatar
Default Re: (red92si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red92si &raquo;</TD></TR><TR><TD CLASS="quote">Spec is:
No less than 50psi @ 3000rpm</TD></TR></TABLE>
that seems really low at 3000, where did you read that
Old Apr 4, 2005 | 04:49 PM
red92si's Avatar
Those are minimum numbers... as in, you want to see more than 50psi @ 3k to be on the safe side.
Old Apr 4, 2005 | 08:51 PM
eMpAtHy's Avatar
u can try a smaller oil filter for a higher oil pressure. i think.
or, you can add like 3-4 more quarts of oil just kidding
try the smaller oil filter. it will not filter as well, but it will keep pressure up.
Old Apr 5, 2005 | 06:19 AM
RemerLex11's Avatar
Default Re: (eMpAtHy)
what difference will slightly higher oil pressure do though?
Old Apr 5, 2005 | 06:25 AM
Greyout's Avatar
Default Re: (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">
that seems really low at 3000, where did you read that</TD></TR></TABLE>
it is the minimum allowable oil pressure, per the service manual.
Old Apr 5, 2005 | 07:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">what difference will slightly higher oil pressure do though?</TD></TR></TABLE>
keep everything properly lubricated, could be the difference between vtec and limp mode...no performance gains, just engine reliability/health
Old Apr 7, 2005 | 07:14 PM
R@mon's Avatar
Default Re: (twistedbydezign)
a smaller filter will only increase pressure before the filter. if you want higher pressure you can shim the pump spring
Old Apr 7, 2005 | 07:47 PM
dmxsoulja3's Avatar
Default Re: (R@mon)
I use valvoline 10W30 on my JDM h22a, at idle I'm from 15-25, crusing, 60-70. wot 75+
trulyshavedintegra
Dec 9, 2012 05:06 AM
RACEPAK
Mar 13, 2006 10:16 AM
fanta!
Aug 11, 2005 02:34 PM
s2kkid
Apr 12, 2005 03:50 PM
Audipwr1
Jul 18, 2003 02:37 PM
