wont start?
Old Apr 7, 2005 | 03:43 PM
mxer518's Avatar
Default wont start?
i am still having trouble getting my h22 started in my 93 lude. the plug where the stock coil plugs into dosent seem to be getting the 12 volt feed required to feed the dizzy? dose anybody have any idea of why this may be?
Old Apr 7, 2005 | 04:56 PM
mxer518's Avatar
Default Re: wont start? (mxer518)
$$$$$$$$$$$$$___$$__________$$$__$$$$_____________ __$$$$$$$$_______ $$$$$$$$$$$$$$$_$$$$________$$$$__$$$$___________$ $$_$$$$$$$$$$_____ $$_$$$____$$$$$_$$$$________$$$$__$$$$__________$$ $$__$$$$$$$$$$____ __$$$$_____$$$$_$$$$_______$$$$___$$$$_________$$$ $$__$$$$_$$$$$$___ _$$$$$___$$$$$__$$$$_______$$$$___$$$$$______$$$$$ $$__$$$$___$$$$$__ _$$$$__$$$$$____$$$$_______$$$$__$$$$$$_____$$$$$$ $___$$$$____$$$$__ _$$$$$$$$$______$$$$______$$$$___$$$$$$$__$$$$$$$$ $___$$$_____$$$$__ $$$$$$$_________$$$$______$$$$___$$$$$$$$$$$$__$$$ ___$$$$_____$$$$__ $$$$$$$_________$$$$_____$$$$____$$$_$$$$$$$___$$$ ___$$$$____$$$$___ $$$$$$$$$$$_____$$$$_____$$$$____$$$___$$$____$$$$ ___$$$___$$$$$$___ _$$$_$$$$$$$$___$$$$____$$$$$____$$$__________$$$_ ___$$$$$$$$$$_____ _$$$_____$$$$$___$$$$__$$$$$$____$$$__________$$$_ __$$$$$$$_________ _$$$____$$$$$$___$$$$$$$$$$$____$$$$__________$$$_ _$$$$_____________ _$$$$$$$$$$$$$____$$$$$$_$$$$___$$$__________$$$__ __$$$_____________ $$$$$$$$$$$________$$$___$$$$___$$$__________$$___ __$$$$____________ $$$$$$$___________________________________________ __$$$$____________ _$$_______________________________________________ __$$$_____________
i need help
Old Apr 7, 2005 | 06:11 PM
mxer518's Avatar
bump
Old Apr 7, 2005 | 11:02 PM
PrettyLude's Avatar
the ignition switch is suposed to give the signal to the dizzy
Old Apr 8, 2005 | 03:37 AM
mxer518's Avatar
Default Re: (PrettyLude)
isnt that plug designed to receive a 12 volt signal to power the coil? is there a way to test it?
Old Apr 8, 2005 | 04:31 AM
digitalh3lix's Avatar
Default Re: (mxer518)
digital multimeter.
Old Apr 8, 2005 | 10:46 AM
mxer518's Avatar
Default Re: (digitalh3lix)
im not that dumb i know i need to use a dvm.....
Old Apr 8, 2005 | 12:22 PM
VTECRaZeR's Avatar
Ok if you tested the damn thing you know is not getting power....Were you cranking it and have the ignition on the on position to make sure it was getting power?
If you did and it's still not getting power that way then is very simple...
Open wire between 12v battery wire end and the power wire to the coil..
Check for power there and at the reference signal from the ignition switch
Old Apr 8, 2005 | 02:21 PM
4.6LJeepXJ's Avatar
Default Re: (VTECRaZeR)
Praise the DVOM its your best friend and your worst enemy.
Old Apr 8, 2005 | 04:42 PM
mxer518's Avatar
Default Re: (4.6LJeepXJ)
if that plug isnt receiving a 12 volt signal what could that mean? wnd is there a way to test the main relay?
Old Apr 8, 2005 | 06:13 PM
the_nautilus's Avatar
I believe an easy test for the main relay is to turn the key on and listen for the fuel pump -- it's pretty quiet, but if it comes on, your main relay is working.
Old Apr 8, 2005 | 09:37 PM
VTECRaZeR's Avatar
[QUOTE=mxer518]if that plug isnt receiving a 12 volt signal what could that mean? QUOTE]
IF you mean the one coming to the coil...
If it's not getting power into it It has an open.....
if it gets power and too much amperage probably has a short
Now if you get power before the coil and no power coming out of it, The coil is bad....
Check for infinite resistance
peter17212
Mar 30, 2009 07:40 AM
ls_vtec95
May 6, 2008 04:48 AM
jchrm80
Jul 20, 2007 08:13 PM
dan89crxsi
Feb 10, 2007 02:44 PM
junglerunna
May 5, 2003 02:59 PM
