idle problem
Old Apr 6, 2005 | 08:39 PM
prelude00sh's Avatar
Default idle problem
I have a 2000 prelude SH and it has been idling funny lately. the idle flunctuates when cold. after the car warms up it idles just fine
Old Apr 7, 2005 | 06:58 AM
RemerLex11's Avatar
Default Re: idle problem (prelude00sh)
mine does too......its not a big deal as long as you dont have a check engine light. mine used to be real bad until i reset the ecu but it still does a little when its cold (but resetting your stock ecu wont do anything).
Old Apr 7, 2005 | 07:00 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: idle problem (Matt5745767)
It could be anything. Check your IACV/EGR for gunk build up. Also, you might have a vacuum leak.
Any mods? How many miles?
Old Apr 7, 2005 | 01:44 PM
Default Re: idle problem (Sticky Tires)
car is stock with about 85000
Old Apr 7, 2005 | 02:08 PM
VTECRaZeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">Check your IACV/EGR for gunk build up. Also, you might have a vacuum leak. </TD></TR></TABLE>
He is very right I have fixed a couple of cars just by hooking up a stupid vacuum line that got looese or leaks in the system.
But it sounds like it might be some EGR related problem because after it heats up it idles fine. If the EGR is stuck open it will give it a idle problem and after the engine heats up it helps keep it cooler and the idle problem will go away.
TegraD
Aug 20, 2008 04:49 PM
91dxhatch
Jan 4, 2007 11:46 AM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
xxredpreludesixx
Jan 22, 2005 06:06 PM
mrnicolas
Oct 31, 2002 02:13 AM
