Compression Test
Old Apr 7, 2005 | 02:08 PM
snowblind7x's Avatar
Default Compression Test
I have a Euro-R engine and the compression test came out 190 all the way across. Does that sound about right or is it low?
Old Apr 7, 2005 | 02:12 PM
slowluder's Avatar
Default Re: Compression Test (snowblind7x)
As long as the numbers are all the same you're fine.
Old Apr 7, 2005 | 02:55 PM
Default Re: Compression Test (slowluder)
so if i had 120's all the way across i'd be fine? O_o
Old Apr 12, 2005 | 12:13 PM
But seriously, i thought Euro-R engines should have higher compression numbers than that. Any one else wanna put their .02 in?
Old Apr 12, 2005 | 12:49 PM
slowluder's Avatar
ok well 120's would be low. But 190 all across is most likely fine.
Old Apr 12, 2005 | 05:58 PM
MUGEN_CF4's Avatar
Default Re: (snowblind7x)
I did a compression test on an Euro R yesterday. Numbers came out 225 accross the board. I also did one on a F20B with 230 across the board as well.
Old Apr 12, 2005 | 08:38 PM
Default Re: (MUGEN_CF4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_CF4 &raquo;</TD></TR><TR><TD CLASS="quote">I did a compression test on an Euro R yesterday. Numbers came out 225 accross the board. I also did one on a F20B with 230 across the board as well.</TD></TR></TABLE>
So you think 190 is a bit low then?
Old Apr 12, 2005 | 08:44 PM
BolivianFuego's Avatar
Yes, but was the motor cold or fully warmed up? Done at WOT until the guage wouldnt read any higher?
Old Apr 13, 2005 | 09:27 AM
accord-lude's Avatar
I have a 92 jdm h22a motor and my compression tested out to be 270 accross.
Old Apr 13, 2005 | 03:51 PM
caLiH22A's Avatar
Default Re: (BolivianFuego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but was the motor cold or fully warmed up? Done at WOT until the guage wouldnt read any higher? </TD></TR></TABLE>
^ This makes a difference on what your readings come out too. But 190 is not that bad off, you should be around 215-230 across the cylinders. Go out there and give that Euro-R motor another try
Old Apr 13, 2005 | 07:16 PM
Well, my friend did the compression test. I wasn't there. He said it was fully warmed up though. And if it was done at WOT, i'm not sure, i would assume so, i think he knows what he's doing, lol. I'll check it out, maybe give it another try. Thanks guys.
Old Apr 13, 2005 | 07:20 PM
Yea tha would be the best. Give it as many hits until the guage doesnt read any higher.
Old Apr 13, 2005 | 08:12 PM
5hif7's Avatar
Make sure the car is warmed up and ur foot is on the floor.
76 camaro car
Apr 20, 2017 04:47 AM
GSR_hatch936
Apr 5, 2007 11:04 AM
crapanese
Oct 30, 2006 10:25 AM
Mr.Integra
Apr 22, 2004 07:55 PM
