help with type s install
Old Apr 6, 2005 | 04:58 PM
rudelude400's Avatar
Default help with type s install
I have a 2001 prelude sh and i blew the motor with nos. i bought a type s motor and installed it. i get no fire. the distributer is a internal coil design. i was going to change it out with the dizzy off my old motor but the cranks sensors do not exist on the new motor and there are no bolt hole to add them. this was supposed to be a stright swap and everything plugged right up so i wonder if the wiring is different. any help will be greatly appreciated.
Old Apr 6, 2005 | 07:47 PM
PrettyLude's Avatar
remove the timing cover and see if there is a crank fluctuation sensor on the oil pump housing
Old Apr 6, 2005 | 09:33 PM
v4lu3s's Avatar
RTFM
afaik there is no such thing as a crank fluctuation sensor on h series engines, thats on B series engines. the h in obd2 should have the CYP and TDC at the oil pump.
Old Apr 6, 2005 | 09:58 PM
PrettyLude's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">afaik there is no such thing as a crank fluctuation sensor on h series engines, thats on B series engines. the h in obd2 should have the CYP and TDC at the oil pump.</TD></TR></TABLE>
u sure about that? JimBlake had corrected me one time on this
Old Apr 7, 2005 | 04:32 PM
it is weird because it doesn't have the sensors on the oil pump. more like the obd1 h22's it is in the distributer. that is what is screwing me up otherwise i would just change overthe wiring harness and all the sensors from my old motor. it also has a internal coil in the dizzy.
Old Apr 7, 2005 | 04:35 PM
also there is no place to muont the sensors on the oil pump like on my old motor. i really don't want to tear it down to change that housing. maybe if anyone has any links to help with the wiring differences between the jdm type s and the us.
Old Apr 7, 2005 | 07:25 PM
v4lu3s's Avatar
RTFM
Personally I think JimBlake is wrong also. I beliueve Honda would agree with me.
#31 37840-P0A-A01 SENSOR ASSY.,
CRANK-TDC
Old Apr 7, 2005 | 07:26 PM
v4lu3s's Avatar
RTFM
Default Re: (rudelude400)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudelude400 &raquo;</TD></TR><TR><TD CLASS="quote">also there is no place to muont the sensors on the oil pump like on my old motor. i really don't want to tear it down to change that housing. maybe if anyone has any links to help with the wiring differences between the jdm type s and the us.</TD></TR></TABLE>
is it really a Type-s? Does it have teh ATTS unit on the back of the block?
Old Apr 7, 2005 | 07:46 PM
yes it is really a type s atts and all.
Old Apr 7, 2005 | 08:24 PM
Shakes's Avatar
space cadet
sorry man but it isnt a straight swap. who ever told you that is full of ****.
Japan does not have "OBD" all of their engines are our OBD I. you will need to convert a few things over on the engine to make it compatible with your car.
since you have the SH you are good on 99% of it, but i believe you will need that crank sensor and a few other things.
Old Apr 8, 2005 | 06:17 PM
thanks for the info. should i just do the swap like i would a obd1 and use the conversion harness. or is it still a little different.
c5 teg
Apr 7, 2019 04:19 AM
formervendor
Jan 26, 2009 05:53 AM
formervendor
Jan 10, 2009 05:19 PM
Boostin_GSR
Mar 13, 2007 02:17 PM
slowpokesi
Nov 15, 2002 11:19 AM
