H22A
Old Feb 23, 2006 | 11:50 PM
slammed95lude's Avatar
Default H22A
So i'm getting a complete H22A swap, well not fully because it is missing injectors and ECU but I am putting in new cams, valve train and pistons as well as rods. any ideas forinjectors I was thinking 370's but what about the ECU...
Old Feb 23, 2006 | 11:58 PM
BDRphaSe2's Avatar
Default Re: H22A (slammed95lude)
just get some stock injectord and a fpr and turn that up im sure ull be fine, unless your going all out in the longrun
Old Feb 24, 2006 | 01:01 AM
mozzandherb's Avatar
Honda-Tech Titanium Member
P13 is the stock ECU I believe.
Old Feb 24, 2006 | 02:57 AM
hu's Avatar
hu
P13 is correct for the ecu.
Old Feb 24, 2006 | 04:21 AM
kulrevon's Avatar
Default Re: (hu)
stock injectors are 345s in the obd1 prelude. and usually you don't need to upgrade those for an all motor unless you are going all out. I would only get the 370's if you get them cheap and you have something to tune it with.
stock computer is the p13 for obd1.
what pistons are you putting in? just remeber that because of the sleeve material you can only use stock. (Or mahale gold series)
S2Integra
Jul 23, 2014 05:05 PM
wrXtian
Nov 3, 2003 03:36 AM
SiC CiViC
Aug 25, 2002 09:16 PM
3gLudeH22A
Jun 9, 2002 06:25 AM
