atts system
Old Feb 28, 2006 | 08:58 PM
jnuanz382's Avatar
Default atts system
i just want to know if the ATTS system is being control by the ECU?
Because i was planning to buy a p28 ecu ?
I just want to know if this thing will affect my ATTS system?
Or the ATTS system being control by the ECU?
Old Feb 28, 2006 | 09:01 PM
skafia's Avatar
25 Year Member
Default Re: atts system (jnuanz382)
Old Mar 1, 2006 | 03:03 AM
Sticky Tires's Avatar
* B A N N E D *
Yes, the ATTS is controlled by the ECU.
Old Mar 2, 2006 | 09:20 AM
tcontesh's Avatar
I actually just had a p28 ecu installed with hondata, and i looked into that problem.
the ATTS unit is actually controlled by a seperate computer.
my atts still works just fine with the p28 ecu.
Old Mar 2, 2006 | 10:52 AM
1GPlusSH's Avatar
Default Re: atts system (tcontesh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcontesh &raquo;</TD></TR><TR><TD CLASS="quote">the ATTS unit is actually controlled by a seperate computer.
Old Mar 2, 2006 | 11:49 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcontesh &raquo;</TD></TR><TR><TD CLASS="quote">I actually just had a p28 ecu installed with hondata, and i looked into that problem.
my atts still works just fine with the p28 ecu.</TD></TR></TABLE>
Really? That's the first I've heard anyone say that the ECU swap doesn't affect the ATTS computer . . . including Hondata.
Old Mar 2, 2006 | 12:07 PM
bubs's Avatar
Default Re: atts system (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">
Really? That's the first I've heard anyone say that the ECU swap doesn't affect the ATTS computer . . . including Hondata.</TD></TR></TABLE>
Same here.. Anyone else care to comment? Are you sure your atts is still working because I doubt the atts light comes on to indicate that it's not working like it does with the stock ecu.
Old Mar 2, 2006 | 02:23 PM
Chuckles99SH's Avatar
Default Re: atts system (bubs)
Your atts is disabled, but your new ECU doesnt know it. hence no lights.
Old Mar 2, 2006 | 06:19 PM
tcontesh's Avatar
Default Re: atts system (Chuckles99SH)
then if the ATTS is on a completely different computer then why would the ecu have any effect on it? Also, my light does come on but only when i throttle it hard in corners because of the setup i have.
Old Mar 2, 2006 | 06:20 PM
jdmlude_dude's Avatar
the 2 computers tie in together. The ecu and the atts control unit. With a chipped ECU, i doubt it will pick up on the atts. Time to ditch it and get a base trans!
Old Mar 2, 2006 | 06:27 PM
tcontesh's Avatar
Default Re: atts system (jdmlude_dude)
BAD IDEA hes just doing an ecu and injectors, he doesnt need to get a new tranny
Old Mar 2, 2006 | 07:14 PM
Daemione's Avatar
Yeah, my understanding is that the ATTS control unit relies on inputs from the stock ECU.
Old Mar 2, 2006 | 09:04 PM
jnuanz382's Avatar
SO if i get a p28 ecu my ATTS will work just find without any light showing or bliking?
Because i want to keep my ATTS system.
So is it wortit to get the P28
Old Mar 2, 2006 | 09:08 PM
vinuneuro's Avatar
Default Re: (jnuanz382)
You need your main ecu to retain atts. Just get something like greddy e-manage to tune.
Old Mar 2, 2006 | 09:34 PM
jnuanz382's Avatar
how much that thing cost Because if out of my budget i cant get it?
Old Mar 2, 2006 | 09:35 PM
vinuneuro's Avatar
First of all, why were you looking at getting a p28?
Old Mar 3, 2006 | 04:09 AM
Default Re: (vinuneuro)
p28 ecus are good to chip because they are cheap. You can customize them to exactly what you want.
Old Mar 3, 2006 | 05:34 AM
vinuneuro's Avatar
Default Re: (jdmlude_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude_dude &raquo;</TD></TR><TR><TD CLASS="quote">p28 ecus are good to chip because they are cheap. You can customize them to exactly what you want.</TD></TR></TABLE>
It'd be one thing to want a p28 for Hondata (or something like it) to tune, but it's kind of ridiculous to just get a p28 to customize .
Old Mar 7, 2006 | 09:42 PM
jnuanz382's Avatar
whats good for my 97 prelude then?
what do you recoment then?
I only put intake, header, cat back exhuast, test pipe?
i want to tune it but i want my atts system running and working do?
Old Mar 7, 2006 | 09:46 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnuanz382 &raquo;</TD></TR><TR><TD CLASS="quote">whats good for my 97 prelude then?
i want to tune it but i want my atts system running and working do?</TD></TR></TABLE>
Apexi VAFC and Greddy E-manage are good option. E-Manage falls somewhere between the VAFC and Hondata. I've only had my 98 SH a few weeks and can understand fully why you don't want to lose ATTS. With only i/h/e both of those options should do the job well.
gettin it
Engine Management and Tuning
Jul 3, 2008 12:41 PM
shivic
Jun 7, 2008 02:38 AM
jarven093
Aug 5, 2007 09:17 PM
kartman
Apr 18, 2007 11:32 AM
tico
Oct 9, 2006 05:19 PM
