reverse light switch problem
Old Feb 25, 2006 | 06:48 PM
tmoney1421's Avatar
Default reverse light switch problem
ok so after an unsuccessful search, i decided to try a post. i recently did a h22 swap into my 94 si lude, and to make a long story short the reverse light stays on unless i put it in 5th gear. does anyone know the proper way to reinstall the switch? we tried taking it out, putting it in reverse, and reinstalling it but it didnt work. any suggestions?? thanks in advance
Old Feb 25, 2006 | 07:03 PM
The Weather Man's Avatar
uh, maybe you have the wires switched?
Old Feb 26, 2006 | 07:03 AM
lunarcry's Avatar
Default Re: reverse light switch problem (tmoney1421)
maybe you got the wrong cable from the auto harness
Old Feb 26, 2006 | 08:06 AM
tmoney1421's Avatar
Default Re: reverse light switch problem (lunarcry)
well the car was already manual, and the wires are a male and female plug connectors so they really only go one way. any other suggestions?
Old Feb 27, 2006 | 12:08 PM
tmoney1421's Avatar
anyone else ever experience something like this?
Old Feb 27, 2006 | 04:51 PM
SteveoBA8's Avatar
Make sure your getting 12volts from the yellow/black wire. The switch could be bad.
Old Feb 27, 2006 | 04:55 PM
yOnKiNaToR's Avatar
i've had that EXACT problem. in my case, my lights didn't work at all so I tested the switch with a multimeter and found that it was bad. so i bought a new switch, put it in, and it did the same thing you're talking about!
after experimentation I found out that the spacing of how far the switch goes down into the tranny is critical. what you have to do is experiment by putting washers on the switch. these washer (s) act as spacer and allow crappy aftermarket switches to operate properly by maintaining properly clearances.
i went through about 2 differently thick washers and found that one washer of a proper thickness worked for me. i actually think i used one of those washers that goes on your oil drain bolt but don't hold me to it.
also, i was told by someone that the tranny should be in reverse while you install it. i don't how important it is, but i did it just in case and my reverse lights work now.
good luck!
Old Feb 27, 2006 | 10:51 PM
tmoney1421's Avatar
Default Re: reverse light switch problem (yOnKiNaToR)
thanks alot for the tips, im gonna try it out within the next couple days and see how it goes
Raven2201
Jul 3, 2013 05:36 AM
Jay_Mills
Sep 5, 2011 06:50 AM
Luvshok
Dec 28, 2009 12:57 PM
H22LUDE808
Jan 5, 2009 12:58 PM
SigmaOmega
Jul 17, 2005 06:55 PM
