cylinder compression
Old Feb 28, 2006 | 01:52 PM
egb16a222's Avatar
Default cylinder compression
hi im not that good with the mechanical stuff so this may be a stupid question owell.
i need to know if your compression on your cylinders is low can you increase the compression on your cylinders, and around how much would it cost
thanks
Old Feb 28, 2006 | 02:45 PM
scootertribe's Avatar
Default Re: cylinder compression (egb16a222)
Well, it could be a piston/ring pack problem. Or oil could be leaking into your cylinder.
So, in order to raise it back up, fix the leak or put in new pistons($$$).
Technically, you could mill your head to raise it up again, but i wouldn't advise that w/out a healthy engine. Good luck, hope this helps some. Cost could be anywhere--depending on the exact problem.
Anyone else have an idea?
Old Feb 28, 2006 | 06:14 PM
CivicSiDriver02's Avatar
Default Re: cylinder compression (scootertribe)
Compression can leak one or both of two places (in general), at the rings or at the valves. You will probably be looking at needing a full rebuild depending on the mileage. The valves could be bent causing improper seating or rings could be shot. Also you timing could be off causing some of the compressed air on the compression stroke to leak out. If you have had your timing belt replaced recently you might want to check that the engine is properly timed.
stir_fry_boy
May 15, 2018 06:27 AM
t-town_ep
12
Feb 20, 2012 04:51 AM
dmonk87
Dec 3, 2011 05:27 AM
zc89hatch
13
Dec 21, 2008 11:40 AM
Lamchop0000
28
Jul 7, 2006 06:50 PM
